Question about Amazon Kindle Fire HD
How can i get my kindle to charge
It wont charge at all
peter schmitt
    Sergeant:
    Champion:
  • 396 Answers
Get new power cord.
Posted on Sep 20, 2014
My kindle won't charge. I have tried 3 different chargers.
Lillian, May have to try hard reset or possibly repair charge port to get battery to start charging. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My Kindle won charge
Kindle Wont Start or Charge How to Reset Kindle
Troubleshooting Kindle Fire That Won Charge
Kindle Fire Won Charge Fix
May 22, 2016 | Tablets & eReaders
Kindle will not shut off-goes to shut off or cancel but wont move. doesnt charge well-doesnt always hold charge
Patricia, Using the power switch, you can forcibly reset your Kindle device. This reset will shut down the Kindle without accessing the shutdown command from within the Kindle's operating system, a particularly useful tool when dealing with a frozen Kindle. To initiate a hard shutdown, Kindle disconnect from its charger, slide and hold the power switch for about 20 seconds. This will force the Kindle to shut down, now it can be restarted normally.
Check links below for charging problems.
Reset Kindle Fire When it Won Turn on or Charge
Kindle Fire not charging
9 common problems with the Kindle Fire HD and how to fix them
Feb 25, 2016 | Amazon Kindle Fire HD
My kindle wont turn on
There might be some issues with the Battery or the Kindle Device. In the last check the charging port of your device. May be kindle do not charged alternatively you can call the kindle support. Kindle Technical Support Registration 877 690 9305
Aug 06, 2014 | Amazon Kindle Fire HD
Why wont my kindle hd charge?
It could be the charger itself. Try taking the USB cable out of the charger and plug it into your computer, then plug in the Kindle. Your computer's USB port should be able to charge it. If it still doesn't charge, you might have a bigger issue with the tablet itself.
Jul 23, 2014 | Amazon Kindle Fire HD
Why wont my kendle modle no do1400 hold a charge
Does the kindle work when you have it plugged in? It could be that the charging port is broken. These models are notorious for broken charging ports.
Jul 16, 2014 | Amazon Kindle Wireless Reading Device
I have a kindle that wont come on an its charge up
First off, I've had 5+ of that type of kindle. Each time the screen was cracked causing the screen to not turn on. If you see any lines this is definitely your problem. If so, you can either replace the screen or replace the kindle.
Mar 11, 2014 | Amazon Kindle 3G
Kindle wont charge
Not all computer USB ports put out enough current to charge batteries. Try another port on the computer, if there is one. If you're going through a USB hub, remove it and connect the Kindle directly to the computer. If you have access to an AC-USB charger (one that plugs into a wall outlet instead of a computer), try using that.
Dec 24, 2013 | Amazon Kindle Fire HD
My kindle wont charge while I'm using it. It only charges when the kindle is off
You didn't specify the model of your Kindle, but the user guide for my Kindle states that it must be turned off to charge.
Sep 21, 2013 | Tablets & eReaders
The kindle won't turn on
It is possible that your Kindle Fire's battery has died. If you noticed the battery life diminishing before it wouldn't turn on at all this may be the case. Here is a site that has replacement batteries for the Kindle Fire:
3555A2L Battery for Amazon Kindle Fire D01400
Dec 31, 2012 | Amazon Kindle Fire HD
`kindle fire
Sounds like your power cord is dead and that it's not charging. If it's new bring it back to the store you bought it from and get a new one.
May 15, 2012 | Amazon Kindle Fire
Amazon Kindle Fire HD Logo
76 people viewed this question
Top Amazon Tablets & eReaders Experts
Ron Rak
Ron Rak
Marvin
Marvin
Jean Thiebaux
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
