Garden Logo
A
Anonymous Posted on Sep 19, 2014
Brand new ltx 1050 cub cadet kohler 24hp engine acts like it is running out of gas have changed gas 3 times still wont run more than afwe seconds
Change fuel 3 times still wont run
Shawn
Level 2:
Scholar:
New Friend:
  • Expert 55 Answers
  • Posted on Oct 12, 2014
Shawn
Expert
Level 2:
Scholar:
New Friend:
Answers
55
Questions
0
Helped
22560
Points
154
More than likely your carburetor has trash and stopped up and needs to be removed and cleaned. The reason it's doing that is because when you crank it the trash in the bottom of the bowl on your carburetor is shaken up and causes the obstruction and blocks the gas from going into the intake where it mixes with air and allowed to be sucked into the cylinders and ignited by the spark plugs. Hope this helps
5 Related Answers
mickey813
mickey813
  • 472 Answers
  • Posted on Oct 12, 2009
SOURCE: Kohler courge sv720-0010 on cub cadet
SOUNDS LIKE IT HAS SOME BAD GAS YOU MAY NEED TO CLEAN THE CARB AND IT MAY NEED A KIT
Anonymous
  • 13 Answers
  • Posted on Jun 10, 2010
SOURCE: cub cadet LT1046 will not start. Battery shows 13
This is most likely a ground problem. Remove the ground wire where it goes to the battery terminal and make sure it is clean. Then remove where it bolts to the frame and make sure that end makes contact with bare metal.
Anonymous
  • 13 Answers
SOURCE: cub cadet lawn tractor, ran out of gas. After
I would bet that the throttle shaft is worn and has a lot of play in it on the carburator. This is very common. The best bet is to have the carburator worked on by a small engine repair shop, or get a replacement one.
Tim Whalen
  • 3076 Answers
  • Posted on May 04, 2011
SOURCE: Cub cadet 42" ltx 1040
http://www.ehow.com/how_6808091_change-cub-cadet_s-drive-belt.html
bryan st
  • 123 Answers
  • Posted on Aug 30, 2011
SOURCE: I need to replace the
Here's a good visual diagram but looks like there is part number variations according to the serial number on your spindle assembly. Hope this helps.
http://www.partstree.com/parts/?lc=cub_cadet&mn=LT1050+Tractor+%282007+%26+before%29&dn=0125700050
1helpful
There is a flashing symbol- black rectangle with two white triangles one on top of the other mower stops but will restart after a few minutes. Cub Cadet LTX-1050, v twin1 Hydrostatic
Make sure air filter is clean or replaced. Check oil level. Change oil if not done this year. Remove plug, clean and gap. Ensure gasoline isn't over 30 days old and use a gas stabilizer if gas cap isn't marked E85.
1helpful
2answers
Ltx 1050 model 13rf91ap056 starter spins but gear wont pop up to engage flywheel
not sure of your vehicle but sounds like Bendix has gone, you need a new starter, or recondition it
New cub cadet ltx 1050 acting like running out of gas.have drained and changed fuel 3 times
Fuel line might be deteriorating and blocked or carburetor might be dirty. Also first thing to check is spark plug and clean it if dirty.
Sep 19, 2014 • Garden
After cutting the grass with a Cub Cadet 1050 after it set for hours the engine
check for water in gas espeially if you leave outside in rain try shooting some starting fluid in it see if it starts up drain gas and fuel lines install new gas fresh not same gas
1helpful
Cub cadet ltx 1045 wont start, no spark.
remove the top cover from the engine and remove the small wire from the coil if still no spark the coil is bad
5helpful
Cub cadet LTX 1050 extension spring where does it go
In case anyone has a 2014 Cub Cadet LTX 1050 KW and needs to know where the damned spring goes when it falls off when removing the belt keeper, here's a photo.
Hello I have Cub Cadet LTX 1050 VT Sv720 23 HPEngine Kohler
This situation is just a clogged fuel line IN the tank. It happens. Yeah, stuff that gets In builds up in the line an elbow and plugs it up. Just pull the connection out of the tank and clean it out. I have even found plastic bits clogging the line on mine. I have a LT 1050 also. And a Cub ZT I just love.
Top Cub Cadet Garden Experts
john h
Steve Sweetleaf
Steve Sweetleaf
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
