McQuay PTAC stops working after short time Heating/Cooling starts but stops after a short time, which seems to depend on outside temperature (cooler temp - longer time working - abt. 5 min). After it stops it cannot be restarted by changing the set temp up or down. Same with the fan - in Fan Mode - fan does not start at all when hot temp outside, when temp cooled - fan works for about 5 min. and then stops. There are no error codes on the control pad. Filters are clean.
Sounds like a voltage or amp draw issue. So how about if you only try to run the blower??
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
SOURCE: stops cooling after a few mins
Check the condenser fan motor It probley has bad bearings and over heats and shuts down
after 15 or 20 min of run time
SOURCE: Amana Cooling Condensing Unit fan won't kick on
be aware that not repairing this asap that you are causing yourself more problems First I would change out the fan capacitor and see if this could be the problem. Secondly if the capacitor isn,t the problem change out the motor . By continuing to allow the system to cycle like this the compressor will take a dive on you costing more . Good Luck
Dave
Testimonial: "Yes, it's dual run capacitor problem. I used a stick to spin the fan blades and it starts to slowly spin and up to normal speed, so motor is good."
SOURCE: Amana PTAC
I know this is late but I had to add a solution to this problem since I had the exact same problem and was able to solve it. The probelm is not your control board. On these units, the heat pump compressor will not kick in unless the temperature you set on the control panel is within 2-1/4 degrees (or 4 degrees depending on your unit model. Otherwise, the unit locks out the compressor until the electric heat coil bring the indoor temperature up to that level - and then will switch the compressor back on for heat pump operation. So the problem is not the control panel or the compressor, it the electric heat coil. The coil has two manual limit switches on it that may be tripped and should be checked. The coil can be easily accessed by shutting down the power, removing 4 screws around the air outlet, pushing the screen up and sliding the panel out the top. The power wires can remain in place while the limit switches are reset. Hope it works.
