Question about Garmin nuvi 350 GPS Receiver
Nuvi 350 System Software Missing
PC not recognizing Garmin USB and Nuvi shows system software missing. I am unable to load Nuvi 350 software as PC wo't recognize USB Port when Nuvi is connected
Posted by Judgelee on
  • 16 more comments
  • Anonymous Nov 29, 2007
    system softeware missing after I tried to update to 5.0. Computer won't recognize USB device. Nothing seems to work.
  • on7tim7 Dec 04, 2007
    Last week I tried to upgrade my Nuvi350 software and I did not read all the installation requirements and with it’s USB cable I connected the unit to my new computer which uses Windows Vista 64. I ran the installation program and everything looks fine only when I turned the unit on it shows “System Software missing”. I have tried to fix the problem reloading on a XP machine the same software it had before my error but it said
    ”software corrupted”.
    I wrote to Garming support and I haven’t got an answer yet and I use my Nuvi every day every where and I go, I am lost with out it. Please, if some one can help me I’ll appreciate it very much.
  • Anonymous Dec 27, 2007
    OMG THANK YOU FOR THE INFO!!!! IT WORKED!!!!
  • Rug Dog Dec 30, 2007
    My PC does not recognize my unit when plugged in. The screen on the unit shows a picture of a PC telling me that the connection is ready.
    I need to update the mapping but I am unable to on the net.
    I downloaded webupdater and at one point it did not recognize or found my unit.
    I found a Garmin CD for updated mapping at Best Buy but I don't know if it is for my particular model.
    I would like to update my software if needed and the map.
    Garmin 350 NA
    Unit ID: 3168023097
    Audio Version: 1.40
    GPS SW Version: 2.40
    Please help.
    Thank you,
    Al
  • sturro1000 Jan 06, 2008
    when i plug the usb in a pop up says device not recognized
  • sawmiller Mar 15, 2008
    I have a new Garmin nuvi 350 GPS Receiver ,when i connect the usb cable to my pc, nothing happing ,have tried everthing, any help . Thanks
  • Anonymous Mar 16, 2008
    update maps
  • Anonymous Mar 30, 2008
    Yes, I have the same problem, after downloading an updating.
  • Anonymous Apr 10, 2008
    beim herrunter laden der software habe ich folgedes Problem de Forerunner 305 zeigt Software Missing an .Was ist zu tun?
  • Anonymous Apr 20, 2008
    MS Vista doesn't recognize Garmin Nuvi 350 connected through USB port.
  • allathelab Apr 20, 2008
  • babber May 07, 2008
    I loaded updated my NUVI 350 firmware with the 5.4 version. After installing on my device fails to load the software and reboots itself. I have reset the device several times but with no improvement. Now, when I turn on the Nuvi350 it says "loader loading...", "Software loading" and then backs out to the copyrite screen. To make things worse, my pc now does not recognize the device and does not assign it a drive. With that I am unable to reload the software.
  • edwardlican Jun 02, 2008
    my window Vista did not see the Nuvi 350 at all. Is there any way to make the nuvi visible to window vista?
  • drvatsson Jun 30, 2008
    I've got the same problem.I have 2 Garmins c330 & nuvi 350.My PC doesn't have any problem to recognize c330 but with the same cable and same software it just refuse "to see" the nuvi 350.
  • stanleyo Jul 12, 2008
    press and hold power button until getting booting message (not preboot mode) worked first time . Thanks
  • nicolass Feb 09, 2009
    the system soft ware is missing when I instaled in my PC
  • Anonymous Mar 24, 2014
    system software missing on c330 garmin
  • Anonymous Mar 25, 2014
    Il connettore USB balla e non fa piu' contatto e l'alimentazione esterna non funziona
banana45
Try this: Hold the power buuton down, you will see on the lower screen the word "Pre Booting - ". Keep holding the power button for about 60 second, then you will see on the lower screen "Booting".
This time, release power button; system will reboot and loading map... again.
I got the same problem, after research on the web. Nick 99990_0 had post this solution on (his Nuvi 660) but it work for my Nuvi 350 too. Good luck.
Minh (NJ)
Posted on Dec 01, 2007
BigWalley3Pu
On my unit the problem is the USB cable. Swap cables (with a USB camera cable) and the problem should be resolved.
Posted on Jun 15, 2008
Anonymous
Geez man thanks for the advice you saved my skin. i updated a garmin nuvi 350 from 4.8 to 5.20 and got the same message (system software missing). if you patient and keep on holdin you get the 'booting' message and its as good as new!
Posted on Jan 01, 2008
Anonymous
Format the GPS, rename it as Host or Garmin. then hit the reset button for 3 second. Turn it back on and then connect it to the computer and reinstall all files.
Posted on Aug 25, 2009
Anonymous
    Problem Solver:
  • 4 Answers
Solution
http://www.gpsgarmingps.com/Copias/SoftwareMissingIng.htm
Posted on Jun 16, 2009
  • Anonymous Jun 16, 2009
    Solution Software Missing
    http://www.gpsgarmingps.com/Copias/Softw...
Anonymous
How do you charge your satnave
Posted on Jul 07, 2008
Anonymous
    Problem Solver:
  • 12 Answers
I was able to successfully update my Nuvi to Vers 5.10 with my computer which runs Vista but the 32 Bit system. From what I read on other Forums it would appear that the Nuvi runs on 32 bits. Start Updater and follow the on screen instructions. It's simple but it would appear that it takes more than one attempt. I was successful on my 2nd try, others have taken 4 or more. If a couple of more re-installs still don't work you can e-mail tech support at [email protected] I have found them to very helpful and fairly prompt (usually within 24 hrs) Good Luck
Posted on Dec 09, 2007
Anonymous
It worked on my Nüvi 310 Euro :D
Thanks !!
Posted on Dec 05, 2007
1 Related Answer
Anonymous
  • 171 Answers
SOURCE: Nuvi 350 System Software Missing
If you have a nuvi 350 download the software to your computer and then load the software onto a formatted sd card. Insert the sd card and bootup the Nuvi 350. The sofware will then load onto the Nuvi 350. If you have a Nuvi 200 I would think it works the same but I have not tried it.
Hope this helps
Posted on May 12, 2009
Tip
Garmin Nuvi 1370 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi...
Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245 , Nuvi 1250, Nuvi 1255, Nuvi 1260
Models: Nuvi 1300, Nuvi 1300, Nuvi 1310, Nuvi 1340, Nuvi 1350, Nuvi 1370, Nuvi 1390
Models: Nuvi 1410, Nuvi 1440, Nuvi 1450, Nuvi 1490
Does your Garmin Nuvi 1370 GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
___________________________
Garmin Nuvi 1370 Manual Download
Garmin Nuvi 1370 QuickStart Download
Garmin Nuvi 1370 Favorites Backup
Garmin Nuvi 1370 Hard Reset
on May 15, 2010 | GPS
Garmin Nuvi 260w not recognized by computer
Take a look at this site, http://www.garmin.be/missing.html Download and unzip the software, plug your garmin in the USB and start the updater.exe program. It gets you started again. Later on you can use the Webupdater to get possible newer software..
It worked for me and my Zumo550
Goodluck
Auke
Jun 01, 2009 | Garmin nuvi 260W GPS Receiver
Hope this helps
May 12, 2009 | Garmin nuvi 200W GPS Receiver
Tip
Garmin Nuvi 1250 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi...
Does your Garmin Nuvi 1250 GPS get stuck or freeze at startup, or when loading maps?
I hope that helps.
Tip
Garmin Nuvi 1245 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
Does your Garmin Nuvi 1245 GPS get stuck or freeze at startup, or when loading maps?
I hope that helps.
Tip
Garmin Nuvi 1240 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
Does your Garmin Nuvi 1240 GPS get stuck or freeze at startup, or when loading maps?
I hope that helps.
Garmin Nuvi 1240 Manual Download
Garmin Nuvi 1240 QuickStart Download
Garmin Nuvi 1240 Favorites Backup
Garmin Nuvi 1240 Hard Reset
Tip
Garmin Nuvi 1210 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
Does your Garmin Nuvi 1210 GPS get stuck or freeze at startup, or when loading maps?
I hope that helps.
Garmin Nuvi 1210 Guide Download
Garmin Nuvi 1210 QuickStart Download
Garmin Nuvi 1210 Favorites Backup
Garmin Nuvi 1210 Hard Reset
Tip
Garmin Nuvi 1200 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi...
Does your Garmin Nuvi 1200 GPS get stuck or freeze at startup, or when loading maps?
I hope that helps.
_______________________________________
Garmin Nuvi 1200 Manual Download
Garmin Nuvi 1200 QuickStart Download
Garmin Nuvi 1200 Favorites Backup
Garmin Nuvi 1200 Hard Reset
on May 14, 2010 | GPS
Tip
Garmin Nuvi 1300 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi...
Does your Garmin Nuvi 1300 GPS get stuck or freeze at startup, or when loading maps?
I hope that helps.
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
on May 13, 2010 | GPS
Tip
How to Perform a WebUpdate of the Garmin Nuvi 205 and 205W System Software
Does your Garmin Nuvi 205 or 205W get stuck or freeze at startup or when loading maps?
One trick to try when your GPS is acting up is to perform a Hard Reset.
Occasionally, your GPS may not start properly at all, and display a 'System Software Missing" message. Today's tip will describe how to restore your Nuvi GPS system software using Garmin Webupdater.
  3. Run the WebUpdater program to install it to your PC and update the system software of your GPS.
Your Garmin Nuvi should be running as good as new.
on Jan 17, 2010 | Garmin nuvi 205 GPS Receiver
Garmin nuvi 350 GPS Receiver Logo
5,066 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
John Egan
John Egan
Janelle Schoonover
Janelle Schoonover
Are you a Garmin GPS Expert? Answer questions, earn points and help others
