Stops mid cycle shows f6
Please check fault codes on page 70 in this manual.
http://www.fagor.co.uk/documents/LFU-65iT.pdf
F6 would mean the water is not getting heated. I am not sure which model you have but if there is only a cold water inlet connection then either heater or thermostat is faulty. If you have both hot and cold water inlet then you may have to check if hot water is getting in at right temperature. Easiest way to confirm is to run dishwasher in cold cycle (short rinse) and see if it goes through. The heater would get used in warm/ hot wash cycles and drying.
