No sound or intermittent sound from rh speaker
Test the cabling. (all cables, also the power cable) While playing some music, careful wiggle the cable on different places. Do the came with the plugs and connectors. If you don't find a place the sound goes of and on, perhaps a bad connection in the amplifier (in the right speaker). When you are not a technician then don't open anything and don't replace cables, unless you know how to do.
Perhaps you better start saving for new speakers. Or you got lucky and could solve the problem by inserting a plug in the right way.
I guess you have tried switching the speaks left to right to check its the speaker rather than the output to the speaker?
If you have it might be worth (If you are able to) opening up the speaker unit to check the wires are still attached and solid, maybe need a little re-solder is needed as the wires are usually very thin.
AUDIO
Revision: May 2004 2002 Altima
AUDIO PFP:28111
System Description EKS002KQ
BASE AND MIDLINE SYSTEM
Refer to Owner's Manual for audio system operating instructions.
Power is supplied at all times
through 15A fuse [No. 31, located in the fuse and fusible link box]
to audio unit terminal 6.
With the ignition switch in the ACC or ON position, power is supplied
through 10A fuse [No. 6, located in the fuse block (J/B)]
to audio unit terminal 10.
Ground is supplied through the case of the audio unit.
Audio signals are supplied
through audio unit terminals 1, 2, 3, 4, 13, 14, 15, and 16
to terminals + and - of front door speaker LH and RH
to terminals + and - of rear door speaker LH and RH
to terminals + and - of tweeter LH and RH.
BOSE® SYSTEM
to audio unit terminal 6, and
to Bose speaker amp. terminal 1.
Ground is also supplied
to speaker amp. terminal 17
through body ground B117.
to speaker amp. terminals 23, 24, 25, 26, 27, 28, 29, and 30.
Audio signals are amplified by the speaker amp.
The amplified audio signals are supplied
through speaker amp. terminals 2, 3, 9, 10, 11, 12, 13, 14, 15, 16, 18, and 19
to terminals + and - of subwoofer LH and RH.
SPEED DEPENDENT VOLUME CONTROL (MIDLINE SYSTEM AND BOSE SYSTEM)
If activated, the radio output volume will be automatically adjusted to compensate for increased driving noises
at higher driving speeds.
The radio receives a vehicle speed signal from the combination meter, and selects the output volume.
