My 1005mfp HP printer scanner error 20 how I solved this problem
Hp are tricky scanners to install and setup. You need to unplug the USB cable, power on the scanner and begin a fresh setup.
Let the software tell you when to reconnect the USB cable to the computer. Let it finish setup and reboot computer. Once in windows, the setup will complete automatically.
Go in START menu and click on the HP Solution Center in the HP folder to activate the scanner.You can't jsut press the SCAN button on the scanner. It won't work. You need to start the software first or use Photoshop.
Also, the way to fix this Error 20 is to first ensure that your HP Printer is set up to be the default printer on your PC. It's often the case that the printer you have on your system will either not be the default, or will have some sort of error that will prevent it from being properly used. You should click onto "Printers & Faxes" on your system and then right click onto your HP Printer, and select "Set As Default". This will allow your PC to use the printer every time you print,removing some confusion.
More Help... HP LaserJet Error Codes and HP Printer Support
Thanks,
Posted on Sep 19, 2014
SOURCE: SCANNER ERROR 12
it is a physical brocken piece that supports scanner mechanism.
if you open that plate /scanner mechanism and if you drill that plastic sheet and try some manufactureed alluminium or metal projection and place it in the hole drilled by you and put washer and screew so that that supports ;the scanner mechanism and your scanner /printer works . the scanner mechanism may costs you around 3,000-00 rupees.
Posted on Apr 19, 2010
Apr 11, 2016 | HP Office Equipment & Supplies
Jun 11, 2014 | HP LaserJet M1005 Printer
Feb 13, 2014 | HP LaserJet 3055 All-In-One Printer
Oct 08, 2013 | HP LaserJet 600 M602DN Laser Printer - M
Jun 11, 2011 | HP LaserJet M1005 Printer
Oct 10, 2010 | HP LaserJet M1005 All-In-One Printer
Mar 10, 2010 | HP LaserJet M1120 MFP All-In-One Printer
Sep 07, 2009 | HP LaserJet M1005 Printer
Jul 11, 2009 | HP LaserJet M1005 Printer
Jun 20, 2009 | HP LaserJet M1005 All-In-One Printer
103 people viewed this question
