Will not work when putting in bread
SOURCE: only toasts part of bread
The solution I got from the FixYa team was: "Get a new toaster." Which is how I ended up with 4 new toasters that don't work. I'm glad I didn't PAY for THAT answer.
SOURCE: Bread toaster doesnt work
It could be the slide button connections or loose wires. You would have to take it apart to try and figure it out. It should be under warranty, though. I don't know if the box is required. You'll have to ask Back to Basics about that.
SOURCE: Russell Hobbs RH2T toaster bread won't stay down w/o hold handle
Hi, most new toaster have a selenoid that hold down the handle while toasting then release when done so a spring bring the toast up. Possible problem with the selenoid, the electronic circuit that controls it or the plate that the selenoid holds. When you lower the handle you close the contacts of the AC line inside the toaster so if the handle is raised there is no power.
SOURCE: Expensive toaster doesn't work
I broke mine trying to fix this, but the fix is very easy. remove the out shell and you will see two prongs with contacts that engage when the plunger is pressed. The plunger will not stay down because the prongs are bent and/or dirty. clean the contact, push the prongs closer to the contact and that should do it. Becareful about how you disconnect and reconnect the wires. That is the mistake that I made, and the fuse blew. BTW, if you fix yours, please let me know what kind of fuse is on it. The fuse is in a sheet in a cluster of wires between the two plungers.
