Question about Kenmore 15864/15862 Top Load Washer
Kenmore elite washer model 110.26922503
Have leveled perfectly yet it still vibrates to much. are there any steps that I missed in unpacking? I did notice a gaskit between the gear unit and the washer tub. the gasget serves no purpose?
Posted by jwombat on
Anonymous
  • 105 Answers
Usually ther is a transit bar that has to be removed that holds the gerbox in place
chek that it has been pulled out from the back
Posted on Jan 28, 2008
While driving the road the transmission will not go into gear less u put your foot off the gas then step on the gas again
Possible missing vehicle speed since to transmission control unit scan it and see if there are any codes present.
Jun 04, 2014 | 1997 Mazda Protege
Flashing yellow arrows
Wet button behind selector activated? If not oil type and level are critical
to Volvo transmissions. Given the age of your vehicle you may need to change it. Mobil ATF3309.
May 17, 2014 | 2000 Volvo V70
Bad vibration while car is not running/moving
The engine light is telling you that the CPU has found sensor/s outside set parameters during the checking process. Have
the fault codes read. Replace faulty items. Use only genuine items as non-genuine replacement are not always compatible with the OEM fitted CPU units Outside of misfiring and missing the only other items to cause vibration are loose fly wheel/cracked flexi plate broken harmonic balancer pulley and fan bearings with an out of balanced fan
Jun 16, 2013 | Dodge Charger Cars & Trucks
It is loud vibrating when comp. runs if I tip the unit up 3or4 inches it stops vibating is this ok too run this way?
No, not really. As the unit has to be in a level position to operate properly and not overflow.
If the unit is sitting on carpet, this will often times cause the vibration noise. I don't know why, but it does and it does with my 4 year old LG unit. I have noticed, that once the tank reaches the 1/2 full point, it will vibrate sometimes. I solved the problem by firmly smacking the left & right sides of cabinet at the same time, with my open hands. The vibration stops immediately and continues to run until it shuts off because, the humidity extraction level has been reached or the tank is Full & needs to be emptied.
It's a simple solution, but it works. I hope it works for you and thanks for choosing FixYa.
Aug 23, 2011 | LG LHD459EL Dehumidifier
Car vibrating while idling
Sounds like it is missing badly and would not be so noticeable when running. Have you had it tuned up lately? Could be wires and plugs need replacing. Also if you have a lot of miles on the engine the compression in the cylinders may be low. Two possibilities.
Jun 29, 2010 | 2003 Mazda MPV
The print cartidge is missing
Please note the printer make and model and visit any computer shop - disclose the model name there they will give you the perfect cartridge. If you know how to fit the cartridge then well but if you don't then unpack the cartridges and please remove the plastic tape from the cartridge head or it will not work, open printer cover up - notice the empty cartridge holder in the printer, there you notice black and color cartridge holder. Look to the cartridge and holder you will understand the position of the cartridge to fit, now push the lower portion of any cartridge to the holder and give a very low pressure on the top (backward pressure to fit the in the holder). Same way you fit the next cartridge. Close the printer cover down. Print any document - it will definitely print.
Jun 09, 2010 | HP DeskJet F380 All-In-One Printer
This is a 1974 charger,360 ,4bbl,auto-problem is engine vibration. engine is running good, butvibrates almost like a miss,noticeable even in neutral, but more noticeable as the rpms are higher.when...
vibrations over 55 mph are usually balance related (tire balance, drive shaft balance, motors)
vibrations at lower speeds are usually mechanical (bent rims, out of round tires, bad tie rods)
Therefore the suggestion for checking the harmonic balancer is perfect in your case.
Thanks
May 09, 2009 | Dodge Charger Cars & Trucks
Kenmore 15864/15862 Top Load Washer Logo
272 people viewed this question
Harvey Mahal
Steve F
JP Meneide
JP Meneide
