What are the meanings for the pre-program code 00-99?
Here are the melnor codes
It means you can enter/set any number from zero to 99
That is not a useful answer. There was a table that came with the timer that shows what schedule the timer would follow based on the number you entered. For example, if you want to water twice a day at 5 am and 6 pm for 1 hour you would enter 63. If you only want to water twice a day for 15 minutes you would use 60; 30 min, 61; 45 min, 62 and so on. If I could upload a photo of the chart I would.
SOURCE: Need manual for t14 gardena water timer 12 yrs old approx
Program Cycle Duration (minutes)
man On Once 30
1 4 times a day 3
2 Twice a day 3
3 15
4 Once a day 3
5 5
6 30
7 60
8 Every 2 days 5
9 30
10 60
11 Every 3 days 30
12 60
13 Every 7 days 60
14 120
Can't believe I saw this...don't usually go on the hunt on the net, but wanted to see if I could source some more of these. I, too, have had my timers for 12 years and swear by them...Excellent product...just happened to go out to the shed today and found the last surviving box, with instructions !!! Good luck, Fiona
SOURCE: I need a new O ring for the battery compartment
just go to the garden center at local home improvment store
It is actually a model #102 and the numbers coincide with the programming of the time or times and duration of your watering cycle. 00 is once a day at 5 am for 15 minutes while 99 is 7 am, 11 am, 4 pm, & 8 pm for 4 hours. I have the chart but no way of uploading it here.
This is the answer. The manual with the codes (00-99) can be found on the melnor.com website under support. Search for model 102. The URL is:http://www.melnor.com/instructions-old/t...
