Question about Amerock Hardware & Accessories
How do I fix a door on a 1995 that does not open at times?
When you pull on the inside handle it will open the door at times and other times it won't.
5 Related Answers
Anonymous
  • 1665 Answers
SOURCE: door handle
Door inside hande may is disengaged Remove door inside panel to inspect.
Posted on Jul 13, 2008
Anonymous
  • 94 Answers
SOURCE: Front passenger door won't open from inside - 2004 Dodge Intrepid
Door panel will have to come off to repair, most likely has broken door handle or cable/linkage problem.
Posted on Nov 30, 2008
Anonymous
  • 92 Answers
SOURCE: drivers side door on my jeep cherokee will not open from inside
most likely the inner door handle has a broken hooking tab for the rod to the latch plate.most door panels are held in place with a few screws around the door pull handle and arm rest than most of the sides and bottom of the door panel are held by plastic snap clips. with a large straight blade screw driver start at a corner of the door panel , slide the blade of the screw driver under the edge of the panel and lightly pry out untill you lossen up one of the clips than slide along the screw driver to the next clip , keep going till the panel is lossened up.
Posted on Mar 29, 2009
Anonymous
SOURCE: inside driver's door handle won't open door
I have a 99 Yukon. Had the same problem. I took the door panel off and discovered that the door handle has a spring attached that appeared to degrade. Bottom line is I changed the entire handle, not too expensive, and it now works fine.
Posted on Jul 07, 2009
Anonymous
  • 143 Answers
SOURCE: The driver's side door could not be opened inside
you"ll have to remove the door trim and replace or reposition the cable/rod assembly that has move out of position not too hard to fix dont worry
Posted on Jun 06, 2010
Passenger door can be opened from inside but not from outside...how too fix???
Remove the door lining and look inside by the lock. There is a linkage that has come adrift. To remove the door lining, remove handles, escutcheons, and arm rests. Using a wide blade screw driver gently pop the plastic rivets that hold the lining to the door.
Dec 02, 2015 | Cars & Trucks
Why won't my driver's door open from the inside on my 2007 Ford Fusion?
Pull on the outside handle up once, then reach inside through the open window and unlock the door, try this and it may correct it self
Mar 04, 2013 | Cars & Trucks
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Help inside door handle for toyota corolla won't open
you need remove the door panel maybe you have only a loose pull wire between the look door or door handle
Aug 27, 2012 | 1989 Toyota Corolla Sedan
1999 Eurovan sliding door won't open
Did you ever get the sliding door handle fixed? I have the exact same problem and would love to know how you fixed it. Please email me at [email protected] thanks!
Apr 24, 2012 | Volkswagen Eurovan Cars & Trucks
Outside handle on 1997 Toyota Avalon will not open door
Since you can get the door open, half the battle is already won. Yes, open the door, pull the interior door panel and take a look around. Watch inside with a flashlight (towards the rear of the door) as you roll the window down to see if you can see what it's snagged on.
Jun 03, 2010 | 1997 Toyota Avalon
Driverside inside door won,t open the dr or even unlock the drs handle is pulled to release?
more likely the door handle mechanism is either broken or came undone, the only way to get to it and see what broken or came off is to remove the door cover panel, its not easy job and its time consuming if not mechanical incline although it something fairly simple to fix and repair. you may just have to replace inner door handle if it broken off from the linkage.
Oct 11, 2009 | 1998 Jaguar XK8
Door handles don't open....
i have the same problem on my 1995 grand prix gtp 2 door coupe...the only differnce is that i had door poppers installed and took off the lock rod, turnes out the solenionds cant pull the latch open, so i need stronger solenoids. but my door wont open either...if anyone has any fixes to this problem let me knows ASAP!! i cant crawl thru the passenger side in the middle of a S. Dak. winter...
Oct 09, 2009 | 1995 Pontiac Grand Prix
How can I dissassemble the door lock from the door handle, it looks like it is intertwined with each other. I am trying to fix the handle in a 1995 ford F 150.
The lock is manuvered by pulling on the inside door release or pulling the lockknob up. Yes they work in conjunction with each other.If you disconnect the link to the release handle the door will no longer unlock with the handle but will still open(unlock) with the key and the knob.
Jun 19, 2009 | 1995 Ford F150 Styleside Regular Cab
Hardware & Accessories Logo
76 people viewed this question
Top Amerock Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Are you an Amerock Hardware and Accessory Expert? Answer questions, earn points and help others
