I bought new remotes to open and close my electric motor controled gate
SOURCE: Remote Control Codes for Phillips TV using Jumbo Remote Control
TRY THESE CODES FOR PHILLIPS:
062 204 184 208 205 206 207 004 288 003 008
068 075 086 087 141 189
SOURCE: Need to program Nova remotes on a Centurion D5 Motor.
Hi
Have you managed to program the remotes
SOURCE: Chamberlain Whisper drive remote control unit not working
THE NEW REMOTE MAY NOT BE THE CORRECT SYSTEM FOR THE UNIT YOU HAVE.
THE ONE THAT DOESN'T WORK MOST LIKELY NEEDS A NEW BATTERY.
NOTE IT MUST BE REPROGRAMED AFTER CHANGING THE BATTERY
HOPE THIS HELPS
SOURCE: I have bought an additional
Steps to Programming Centurion Nova Remotes 1. Unlock the motor cover with your Centurion Key, remove this cover. 2. Inside the perspex enclosure there is a small Receiver Board (approx size of a matchbox), identified by wording CENTURION CP9Z, also has the wording J1-Learn; J2-Erase. 3. There will be a small 'shunt' placed on one of the pins labelled J1, J2 or the centre pin - these are the 'Learn' pins. 4. Remove this shunt and place it over (or bridge) the J1 and centre pin together. The red LED Status light, to the left of the Learn Pins will illuminate. 5. Remove the new Remote/Transmitter from its packaging, hold down the required button once and the red LED Status light on the Receiver Board will flash once indicating that the button has been learned. As soon as the light has flashed, remove your finger from the button. 6. If further Remotes/Transmitters are to be added to the system, repeat step 5. 7. Ensure that you now remove the 'shunt' and place it back onto the blank or J2 pin - do not leave it bridging two pins. 8. Close the enclosure, place the motor cover back onto the motor and lock in place.
