Question about Pride Mobility Products New Pride Mobility Jet 3 Ultra Power Wheel Chair
Remove the seat from jet 3 power chair?
Trying to change the batteries.
4 Related Answers
Anonymous
  • 29 Answers
SOURCE: jazzy jet 3
Look in your owners manual for the flash code anwser. Make sure when you hit the power button you only touch it for 1 sec not more. If you press the power button for more the 2-3 seconds you place the power chair in LOCK OUT mode. lights will flash and not power. also check your free wheel levers. one on each moter. Mike
Posted on Sep 07, 2009
Neil Wood
  • 177 Answers
SOURCE: can you put larger tyres on a jet ultra 3 power
Hi. This is a question that has a lot of for and against points.
Bigger tyres will mean a slightly more comfortable ride, but it will cause other problems.
Putting on larger diameter tyres means that you are altering the gearing from the motor to tyres. You will have the potential to travel slightly faster, but the machine will struggle more on slopes and ramps. You will find there will be more places where the machine will get stuck because it doesn't have the power to climb out of certain hollows in the road or footpath.
Good luck. Neil.
Posted on Jun 04, 2010
wcdoc1953
wcdoc1953
  • 280 Answers
SOURCE: I HAVE A JET 3 ULTRA CHAIR, WE LOSS THE 24V PRIDE
You can use the AC charger cord from a computer as a replacement for the AC cord of the charger. If the AC cord plugs into the wall and plugs into the charger or charger receptacle on the back of the power chair, you can use it.
If I remember correctly, This chair has a 4 Amp on-board charger which has an AC receptacle on the back of the chair to plug in an AC cord. The off-board chargers take a universal AC cord which will work with a universal computer AC cord. If the AC cord plugs in, use it.
Posted on Nov 25, 2010
lennieg2000
  • 692 Answers
SOURCE: When I turn on controller
Do all of the speed lights flash at the same time or do they ripple from left to right? If they ripple from left to right the chair is in lock mode and you can use the unlock procedures from my tips to unlock. If they are all flashing at the same time you have an internal joystick problem and the joystick needs to be replaced Hope this helps
Posted on Apr 28, 2011
Replace battery for the jet 3 ultra
\hmm what do u need to know? how to replace battery?if so take seat off then take off shroud and u will see batterys,make a wiring diagram of how batterys are conected before u remove them, good luck
Jan 20, 2014 | Jet 3 Ultra Power Chair
How do i connect the 35 amp batteries to my ultra 3
with the battery cables vic seriously I'm gonna assume you have removed the seat and shroud cover over the batteries. Unplug the battery cables from the wiring harness and remove each battery remove the wiring harness from the battery and attach to the new batteries like they were to the old red on positive and black on negative and reinstall in the chair plug the joystick cable back into the chair turn on the chair to make sure you got it right unplug the joystick cable replace shroud and seat plug the joystick cable back in and you should be good to go. charge the batteries before use and then charge them nightly when you go to sleep and unplug in the morning if you use the chair daily charge everynight If you have to stop using it for a while always put it up fully charged and charge weekly Hope this helps you
Apr 09, 2011 | Jet 3 Ultra Power Chair
I want to take the batteries out of the power chair, how can i do this
Flo First you have to unplug the nine pin connector at the rear of the chair and the 3 pin charger plug. Then there is a handle under the right side of the seat. Push it forward to release the pressure on the seat post. Now the hard part have someone with some strength twist and pull up on the seat at the same time until it comes off the seat post. After the seat is off then remove the plastic shroud covering the base and there you will find the batteries. Unplug the battery cables from the wiring harness and lift out them of the base. Hope this helps you
Mar 02, 2011 | Jet 3 Ultra Power Chair
How do i remove the chair. I want to change the batteries
Bob First unplug both connectors from the rear of the chair. Then on the right hand side under the seat push the small handle forward until it stops, then rotate the seat and pull up at the same time the seat should lift off the seat post. Carefully place the seat on the floor next to the base. Remove the shroud pulling upward to release the velcor fastners and voila!! the batteries. Now if the seat is hard to pull up try twisting it back and forth to help get it loose from the seat post. You might need some help in lifting because this seat and attached parts are heavy. After replacing the batteries grease the post to help getting it off easier next time. Hope this helps you
Sep 29, 2010 | Pride Mobility Products New Pride Mobility...
Directions to replace the battery in a jet3 power
Unplug the joystick cable under the seat remove the seat if on a post lift handle on right side under seat and lift seat off post if not look for release levers behind front seat post and seat will rotate backwards to give you access to the batteriesdisconnect battery cables and install as on old batteries to new ones and reinstall Hope this helps
Aug 02, 2010 | Jet 3 Ultra Power Chair
HOW DO I REMOVE THE SEAT FROM A JET 3 POWER CHAIR
It has a lock lever on the side. Push the lever and turn the seat slightly while lifting up with both hands. Sometimes, they need a pretty hard **** to get it to release, but it will come right off.
Nov 28, 2009 | Jet 3 Ultra Power Chair
How do i remove the battery?
Remove the seat and then the support that covers the batteries
Oct 20, 2009 | Pride Mobility Products New Pride Mobility...
How do I remove the chair from my Pride Mobility Jet 3 power wheel chair? The manual just have one line of description! Do I need to remove the chair before getting by hands on the battery? My Jet 3 is of...
There's a lever on the side of the chair that you disengage to unlock it. First, make sure the chair is in gear and power is off, then unplug the Joystick from the base; just follow the cable coming out of the joystick to the rear of the chair where it plugs in and rock it back and forth to unplug.
Unlock the seat with the lever, and turn the seat slightly to the left or right and lift up. Usually, it will come right off. If it's been a while since it's been removed, or if a heavier person has been bouncing atop it, it may need more coaxing. Try squirting some WD-40 at the base of the seat where the pole connects and let it run down into the shaft of the pole. Wiggle seat back and forth a bit and try lifting at the same time.
Now you can access the batteries by lifting up on the corners of the cover called the shroud. These are held on by Velcro strips so just pull up and they will give way. You will see the two batteries inside. Replace them with sealed, gel-acid deep-cycle batteried, about 32-34 amp-hour rating. Fully charge for two or three hours before using. On first uses, let the batteries discharge almost to the red zone before charging overnight. After a week, they will be well broken in. Good luck.
Jun 30, 2009 | Jet 3 Ultra Power Chair
JET 3 POWER CHAIR SEAT REMOVAL
Sometimes it just takes some real elbow grease to remove those. Try two people one on each side.
Mar 30, 2009 | Jet 3 Ultra Power Chair
Pride Mobility Products New Pride Mobility Jet 3 Ultra Power Wheel Chair Logo
75 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Bird
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
