Question about Sony Bravia KDL-40V4100 40 in. LCD HDTV
My Bravia suddenly lost color, I I see only vague white shadows, audio is fine.
There is no color but there are vague shadows that move
Posted by Ann McIlvain on
    Top Expert:
  • Sony Master
  • 76,360 Answers
T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Posted on Sep 19, 2014
2 Related Answers
Chi Chu
  • 8457 Answers
SOURCE: TV suddenly lost the ability to project red
Reset the colors setting back to factory original setting.Should have all colors back to original.Not than ur main tuner signal board is dead,must replaced.
Posted on Jan 12, 2010
fredback99
fredback99
SOURCE: Sony Bravia KDL 46V100 has only black & white picture-no color
I bought Sony Color Bravia TV 60 inch, moved with it Kenya, Africa, when i try to tune the color is not coming. I can only get black and white. Please anybody with idea on how to change it for Africa (Kenya). Model:KDL-52SS100. My e-mail. [email protected]
Posted on Jun 04, 2012
Sony Bravia 46" It is 6+ years old and the color is completly out of reality has only blue,green and white and black . is this normal aging or fixable .
A faulty Tcon board is often found responsible for wrong colour type faults. Some times the main board is also found faulty. If it has happened all of a sudden, it is not aging.
May 07, 2015 | Sony BRAVIA KDL-46XBR2 46 in. LCD HDTV
Our sony bravia has no blue color
If you are using the component video hookup which is 3 wire. green, Blue ,Red and red and white audio. be sure that all 3 of the video wires are pushed in all the way. check both ends. Replace cable. if all 3 are not connected then color will be be goofy. Let me know if this doe not help.
Aug 30, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Hi, I'm trying to connect my ACER 5738 notebook to my Sony Bravia KDL-W4500 via the HDMI connections. I can get video fine, but no sound, it still comes out of the notebook speakers. Any ideas?
Buy an audio cable: stereo jack male at one side and RCA Audio on the other end. Connect the male jack to the laptop's headphones and the RCA channels to the audio inputs at the back (you will see the two channels - white and red colored ones).
Feb 21, 2010 | Acer Computers & Internet
Sony Bravia 40'' LCD 240Hz TV can't get video signal from DVD
Are you absolutely sure you have it wired up right? Are the Cable RIGHT wires color to color, is the "Correct Input" selected? Remember you do NOT use "Channels" but an AV, AUX, or External.input. Most DVD etc, use AV, IE: Yellow, (Video), Red, (Audio), White (Audio) for the OUT connections. These go color to color at TV end. And uses 3 Cables. The "Other" type of Output/Input is Component Video. This is ALL Video, Red, Blue, Green, these go color to color as well. BUT you MUST also send the Sound, Via the AV, IE: The Red & White, AV, Audio IN/OUT connections, So you in this case would have 5 cables/connections in all.
Feb 13, 2010 | Televison & Video
Jan 12, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Can't not get our Nintendo 64 to work on our new Bravia TV
The Nintendo 64 sends out a signal that can only be properly decoded by old CRT TV's
Those Bravia TV's are the God's TV's even if they did work on it I wouldn't recommend it because it would most definitely eventually ruin the life span of your TV.
But to answer your Question the Cables should be plugged into AV1 which is the Red White and Yellow Connections
Nov 22, 2009 | Nintendo 64 Console
Jun 30, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Dell 5110cn Printer Printing Blue Shadows
I did the following and it has stopped printing "shadows". I don't know if it was one solution or the other (or both) that worked.
1.On the face of the printer press the "Menu" button>Admin Menu>Maintrnance>Color Reg Adj>
Auto Correct>Yes
2. "Menu" button>Admin Menu>Maintrnance>Clean Developer>(Pick problem color)>Yes.
Hope it helps
Aug 16, 2008 | Dell 5110cn Laser Printer
Red shadows
Iam having the same issue where i cannot align the RED color ,iam elect savy so if any one can guide me to repair it i would be able to do so
Dec 01, 2007 | Panasonic PT-47WX53 47" Rear Projection...
No Color
did u try cleaning the video head? heres how! unplugged the unit. open the cover. get a piece of clean white paper. put a little alcohol on it. place your finger on the paper and slowly touch the head but not too much force then gadually move the drum back and forth. donot move your finger up or down. just clean it horizontally by slowly moving the drum leaving your finger stationary. let it dry and test. if the problem persist see a doctor(technician), u have a problem with the color circuits. good luck!
Jan 31, 2007 | Aiwa HV-MX1 VHS VCR
Open Questions:
See all Sony Bravia KDL-40V4100 40 in. LCD HDTV Questions
Sony Bravia KDL-40V4100 40 in. LCD HDTV Logo
153 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
