WHAT TO DO WHEN UNIT IS FLASHING CH 03
WONT DO ANYTHING EXCEPT FLASH CH03
    Sergeant:
  • 338 Answers
You have a thermistor problem probably the one outside its a black wire that has bulbs on them one on the coil on the outside and the other is on the coil tubes on the inside of the unit.
Posted on Sep 19, 2014
Anonymous
SOURCE:
My lg-vn-217 phone flashes off an on on the screen
Go to
mobile/bigresorce.com
They have several options for you to try.
Dec 24, 2014 | LG Extravert MobiPhone - Black Verizon...
Wont charge. Wont do anything except a little flash of red battery then dead.
Check your charger in a different iPhone, or the sync cable also. Check to see if your dock connector isn't tarnished, if it is clean it with a CLEAN DRY used toothbrush. Has your phone been wet? I hope it isn't the wet problem! Good luck!
Oct 29, 2013 | Apple iPhone 3G
My tv has to be on ch 03 to watch satelite but now CH03 is on the screen how do i get rid of it
With the original remote you would hit display, if no display on this remote you are out of luck. Sooner or later if display up all the time it will burn that image into the screen.
Nov 03, 2012 | Radio Shack (15-2147) Remote Control
New cartridge wont work and power and ink lights flashing.
You probably need to remove the protective film from the contacts on the cartridge. murf427
Oct 25, 2012 | Epson Stylus All-in-one Inkjet Printer...
Facebook games will not work i need a flash player and install
Go to Adobe.com and download the Flash player there. It will install itself. Uncheck the box for the add-on, you don't need it and you shouldn't install anything except the flash player.
May 06, 2010 | Macromedia Flash MX Pro 2004
Im getting p!$$e{} off
IS their a STATUS button? Press that. It should cycle off the CH03. ONe of the buttons will do this.
Apr 13, 2009 | Sanyo DS27510 27" TV
DVD/VCR does not work on my LCD
Use a co-ax cable. put your tv on ch03
Mar 02, 2009 | Emerson EWD2203 DVD Player/VCR
Canon a 620 flash
Here are some simple things to try first for a camera that won't take a picture when the shutter button is pressed, or with an inoperative flash. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2008/05/simple-fixes-for-cameras-that-wont-take.html
Apr 03, 2008 | Canon PowerShot A620 Digital Camera
Now using satellite dish
Not likely - - there is nothing on the remote that would cut-off the signal, unless you have selective inputs and you were not viewing the correct one. However, "cable" CH03 is correct if your satellite is attached to the screw-on "F" connector in the back of the Tv... When you press menu on the reciever does a menu appear on-screen??
Bill
Dec 01, 2007 | Prima C2012 TV
Open Questions:
Honeywell VisionPro TH8110R1008 controlling a Carrier FA4ANF018 electric furnace/AC. Heater won't turn on. Honeywell VisionPro TH8110R1008 controlling a Carrier FA4ANF018 electric furnace/AC. As best I can recollect, the sequence of events went like this: Furnace was working normally. Thermostat was set at 70. Turned temperature on thermostat down to 67 and left the apartment. Didn't notice if furnace was running or not at the time, nor if it was running and shut off when I lowered the temp. Came back an hour later. Furnace was running and temp was up to 72 degrees. Thermostat looked normal. No indication of low batteries. Tried turning the system off on the thermostat. Furnace continued to run. Nothing on the thermostat would affect the furnace. Eventually turned off the circuit breaker (for the apartment electrical, not the breaker on the furnace) to stop furnace. Waited. Turned breaker on. Furnace stayed off. Batteries failed in thermostat and screen went dark with barely readable failing battery message. Put in new batteries. Thermostat fired up but still wouldn't control the furnace. Switched to cooling. AC went on. Couldn't turn AC off. Had to turn breaker off again. Turned breaker on. Thermostat displayed "Wait" message when I tried turning on the furnace. Waited half an hour. Wait message disappeared. Still can't turn furnace on. Slid out lithium backup battery and slid back. Thermostat makes appropriate click sounds as if it is turning the furnace on or off, but furnace doesn't respond. Equipment Status screen shows furnace on or off depending on thermostat settings. Set thermostat to System Off. Checked breaker on side of furnace. Was off. Turned on. Turned temp up on thermostat. Thermostat clicked, but furnace did not go on.
Feb 15, 2020 | Carrier Heating & Cooling
Heating & Cooling Logo
228 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
