My phone was working ok but all of sudden there was no tone, then when i pick up the phone, it was full of static and buzz, cannot dial out because the release button on the phone wasn't working, even if i put the phone down, now today i hear it ring and i pick up but there is some sort of a buzz and cannot hear the person who called
SOURCE: no dial tone at all
if the non-cordless phones are ok, it sounds as if the cordless handsets are the only ones not working, have you charged the batteries on those handsets ok and are there any signs if life, eg lights or on-screen messages ? Are they switched off ?
If there are signs of life, check the level of charge, if dead completely, take it/them to the main unit and put on charge for about 10 hours, if they work for only a short time and you have had the phones for a few years, then you will need to replace the re-chargable cells as they don't last forever and they are not holding the charge.
Hope this has given you some clues.....
SOURCE: phones don't ring
Caller ID is a service that is provided by your telephone service provider and not the phone. If the phone company isn't sending your line Caller ID data, your phone won't display it. As for getting the handsets to ring, try pushing the volume up key while the handset is off, the more times you push the button, the louder the ring will get until you are at max ring volume. Also, some models have a "Do Not Disturb" feature which turns the ringer off. Without knowing which model phone you have I cannot tell you how to turn this feature on/off. but you can look it up in your manual online at http://www.uniden.com/index/manuals_results.cfm?cat=1
SOURCE: My BT Verve 450 digital phone set won't ring out /incoming call
My GE cordless handset won't ring when it's on the base charging but it will when I take it off. I've taken off the battery and disconnect the phone from the wall to try to reset it, but it still doesn't ring.
