Question about Brother IntelliFax-2820 Laser Fax
What do I need to due when the message comes on change drum for a brother intellifax 2820
What do I get when it says to change the drum
5 Related Answers
Anonymous
  • 47 Answers
SOURCE: Error message won't go away.
This message would continue to appear if the drum counter was not reset when you replaced the drum. To reset the drum counter, follow the instructions listed below.
  1. Open the front cover.
  2. Press the Options key on the control panel.
    The display will show "REPLACE DRUM - 1.YES 2.NO".
  3. Press 1 to reset the drum count.
  4. Close the front cover.
Posted on May 28, 2008
Anonymous
  • 25 Answers
SOURCE: FAX SAYS TO CHANGE THE DRUM SOON
Open the front couver as if you are about to change the drum unit. With the couver still open, press the options button for a while and in the display will apear a message asking if you want to change the drum unit. Choise the yes option and close the front couver. GOOD LUCK.
Posted on Nov 13, 2008
Anonymous
  • 318 Answers
SOURCE: can't reset "change drum soon" message Brother Fax 2820
Open the front cover and press and hold -stop,reset button
Posted on Sep 15, 2009
MalKontent68
Stan
  • 748 Answers
SOURCE: Brother IntelliFax-4100e Fax Reset drum counter
With the front cover still open, you should press Clear ("Replace Drum?" should appear on the display), and then 1 for Yes. Wait for "Accepted" message and close cover.
It may be necessary to remove the drum unit and put it back in, and then, with the cover open, do the a/m procedure.
Posted on Nov 07, 2009
Anonymous
  • 405 Answers
SOURCE: How to change date and time on the Brother
1 Press Menu/Set.
2 Press 0.
3 Press 2.
4 Enter the last two digits of the year on the
dial pad, and then press Menu/Set.
(e.g. Enter 0, 7 for 2007.)
5 Enter the two digits for the month on the dial
(e.g. Enter 0, 3 for March)
6 Enter the two digits for the day on the dial
(e.g. Enter 0, 1.)
7 Enter the time in 24-hour format on the dial
(e.g. Enter 1, 5, 2, 5 for 3:25 P.M.)
8 Press Stop/Exit.
Posted on Jun 12, 2010
What we can do for brother fax-2820 " DRUM ERROR"
open front cover with the machine on and press the options key.message will appear replace drum unit then select 1 for new.close cover
Oct 25, 2012 | Brother IntelliFax-2820 Laser Fax
IntelliFax-2820 Plain Paper Laser Fax: We have a Brother intellifax 2820 and it's aking t...
You need to take out the cartridge and slide the tab on the top right from right to left about 20 times
May 16, 2010 | Brother IntelliFax-2820 Laser Fax
Can't reset "change drum soon" message Brother Fax 2820
Sep 14, 2009 | Brother IntelliFax-2820 Laser Fax
Change toner error brother 2820 mach has new brother toner ctg
with machine on, open front cover, press the "options" button, you should see "replace drum?" press the "start" key then 1 then 0. display should show accepted for a couple of secs. then show cover open. close front cover and message should be gone. if not, you will have to contact Brother.
hth,
razors
Jan 23, 2009 | Brother IntelliFax-2820 Laser Fax
Nov 13, 2008 | Brother IntelliFax-2820 Laser Fax
May 16, 2008 | Brother IntelliFax-2820 Laser Fax
Brother 2820
The toner cartridge is in the drum unit. push the blue lever and the toner pops out, make sure you have a toner cartridge in the drum unit. Lawrence
Apr 23, 2008 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
Norman  J Weimar Jr
Norman J Weimar Jr
k24674
