Question about Panasonic PV-C2780 27 in. TV/VCR Combo
Can I connect a DVD player to a Panasonic PV-C2780? How do you get the TV to recognize the front audio/video ports?
Will I need the remote? I have the DVD player connected to the front input ports, but do not know how to get the TV to use this input source.
6ya staff
SOURCE:
Anonymous
  • 192 Answers
SOURCE: Component Video inputs do not work
I started back in the day of tubes. A family would have one set and it would be a 19" black and white. There are different resolutions now. The components probably do work, but, they don't pass the 480i signal. The satelite converter's analog signal needs to be set to 480p and the DVD needs to be set to progressive if it does have that setting. If the DVD is not a progressive scan DVD, then, the only inputs that it will show on is the analog signal. Some of the dish converters have a switch on the face for changing the resolution. If yours doesn't then put it in an analog source and go to the menu and change it there. Then move it to the component input. Hope this helps.
Posted on Jun 24, 2007
simplemitch
Mitch
  • 752 Answers
SOURCE: Adding DVD player
yes, you can use the video,audio in's on the front.
Posted on Sep 10, 2007
foamesh
  • 7 Answers
SOURCE: CONNECTING THE PANASONIC SC HT680 TO A SONY TRINITRON COLOR TV AND CABLE BOX
audio/video OUT from the cable box to the aux IN on the panasonic right? So you can see the output from the cable box but only sound from dvd. Are you changing the input on the tv when you go from watching the cable box to watching the DVD? the panasonic handles audio, but the video from each goes to two different inputs on the sony. I hope none of this sounds condescending.
Posted on Jan 29, 2008
Anonymous
  • 3 Answers
SOURCE: Need remote control code for Panasonic PV-DF2703
I found a newer Comcast PDF file that shows a 5 digit number for tv with vcr ( no mention of DVD) but the code worked to turn on the tv and cable box together. My problem is it won't work the volume, yet
https://www.comcast.com/MediaLibrary/1/1/Customers/Customer_Support/Digital_Cable_with_OD/Digital_Cable/remotes/Remote_M1067BX3.pdf
Posted on Dec 30, 2008
Anonymous
  • 37 Answers
SOURCE: No video with HDMI port
try 2 things, first use the rgb cables or video (yellow) cable and plug it into the tv using one of the imports..(vid 1,2,3 etc...) and see if that works. then check to see if you get a picture by not using the cable box, by pass it and connect it connect it in the uhv channel. also make sure you have it on the right input of the tv (meaning scroll through the input button on your remote to find the picture...i've done this a million times). still no picture try your dvd player input and if you have a vhs input see if that works. if it is the hdmi input...to be honest it's expensive and a pain to replace...
Posted on Mar 12, 2009
Describe your Panasonic PV-D4743 DVD Player / VCR Combo Problem I DO NOT HAVE REMOTE FOR THE DVD/VCR. WILL A UNIVERSAL REMOTE SOLVE THIS? I HAVE A SHARP TV WHICH ALSO LACKS A REMOTE.
Universal remote may give you few controls like power on-off, FF, REW etc but Menu may not open.
Substitute remote for this Combo is available in Remotes.com and original remote is available in Panasonic Parts under part number LSSQ0374
Same thing goes to your Sharp tv.
Thanks.
Jul 02, 2011 | Panasonic PV-D4743 DVD/VCR
Will a dvd player work with a Panasonic PV-M2023 combo TV VCR, built in 1993? We connected a DVD player but haven't been able to get it to work. We have the original remote control.
I see that it does have RCA input (Yellow, white, red) on the reverse of the TV. Connect the DVD via RCA cable to the corresponding color connection, place the TV in "Vido" or "aux" mode. this is usually done on the remote from an "input" button, or it can also be called "game," "video," or "aux."
Upon putting it to this after connection of the DVD player, you should see the DVD players home screen. You should be set to enjoy the DVD player.
Jun 28, 2011 | Panasonic Televison & Video
Howdo I hook a DVD player up to this model?
The easiest way would be to hook it up using the composite cables from the DVD player to the Rear of the TV.
First safely and slowly turn your TV around you should see inputs in the rear of the TV.
Second identify your composite inputs. They will be visible via the standard RCA Composite colors, which are Red(Audio), White(audio), and Yellow(Video)
Third Once you have found the RCA Composite Inputs, Take the cable which are inserted into the DVD player and Plug it into the TV's Composite Inputs.
Once all that is done, turn on your DVD player. Then using your TV's remote Press the "TV/VCR" / "Source" / "Input" button on your remote till you see video from your dvd player displayed on your TV.
Here is a link to the User Manual:
http://www2.panasonic.com/consumer-electronics/support/TV-Combos/model.PV-C2540
Hope this Helps.
Mar 18, 2011 | Panasonic PV-C2540 25 in. Combo
I recently connected a Panasonic DVD player to our 47lg50 LCD television using an S-video cable. I cannot get sound so am assuming I need another cable to connect to the audio out ports on both and dvd...
Yes, you are correct - S-video does not have provisions for audio - it is strictly video. To connect audio, you need two RCA cables, normally colored red and white, right and left respectively. Connect output to input from the source to the destination. The source is the DVD audio out and the destination is the TV audio in.
Dec 16, 2010 | LG 47LG50 47 in. LCD HDTV
No color or sound on DVD Player when hooked up with the ShowStopper
Svideo requires the audio cables too, Red and White. Svideo is only carries video.
Dec 30, 2007 | Panasonic PV-HS2000 Showstopper 30-Hours...
Adding DVD player
Sep 09, 2007 | Panasonic PV-C1321 13 in. TV/VCR Combo
How to Record From a TV Using PV-GS13?
connect a lead via your tv video out audio out jacks. Select tha appropriate channel (You may have to go through the av channel on you tv and tune in the channel you want to record) or, video or dvd player audio out video out jacks. connect other end to your camcorder. Select on the camcorder menu video in audio in. Turn on tv. If connected to video or dvd player, press play. Press record on your camera. When finished recording press stop. Presuming the camcorder is tape, you can buy a tape adaptor to play or record your mini tapes in a standard video recorder, then take them out of the adaptor and play them back on your camcorder. You can also do all this via a computer. Also if the camcorder is disk or hard drive it can be used the same way as a regular dvd recorder to record tv programmes once connected to you t.v. Let me know how you go 26 red
May 08, 2007 | Panasonic PV-GS31 Mini DV Digital...
No Sound
sounds like a cold solder connection on the audio output ic?? maybe even an audio plug from the deck assy.
Apr 05, 2006 | Panasonic PV-C2780 27 in. TV/VCR Combo
Audio shorting out
sounds like a bad connection on the audio output Ic or in the audieo curcuitry
Panasonic PV-C2780 27 in. TV/VCR Combo Logo
76 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
