Question about LG 42PX5D 42 in. Plasma HDTV
42 "my tractor ain't charging the battery
Not charging ?
Will not start just a solenoid clicking sound
check battery to see if it's charged and if it is be very careful and jump the solenoid and it start's when you jump the solenoid then it need's to be replaced.
Sep 07, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Does a Cub Cadet Model 1170 lawn tractor charge it's battery ?
when a engine has factory electric start it will have a charging system but it is only a couple amps keep in mind a small mower battery is only good for a couple years
May 12, 2012 | Cub Cadet Garden
Battery reads full on the charger but mower acts like battery is dead and won't start
It may show a full charge but when you go to turn the engine over it's draining the charge and there's not enough of cranking amps to keep it turning over. I would suggest installing at least a 350 cranking amps. This will not hurt the engine but it will give more power to turn the engine over to start. A lot of cheaper batteries are only 200-275 amps but don't last long.
Sep 05, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
18hp kohler engine (grasshopper) won't start. Single click from starter/solenoid when key turned. Battery new/charged.
I have a duetz-allis mower with 18hp. kohler eng. won't start, have new seloniod, new circuit breaker, getting fire to switch & out. Still won'tstart
Aug 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Battery will not charge
IS THE BATTERY GOOD,IF THE BATTERY IS BAD IT WONT CHARGE IT,IF ITS GOOD THERE SHOULD BE A 20 AMP FUSE FOR THE GHARGEING SYSTEM
Mar 24, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman 24 kohler engine
there is no alternator on small engines it is called a stater which is usually on the coil all one unit with coil but does the battery charge on a battery charger the battery might be bad & wont take a charge let me know if i can further help thanks wade
Jul 02, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a craftsman electric key start lawn mower. I used the key start twice and have charged it after each mowing, but now the key start won't turn it over.
the battery probably got over charge & shorted the cells the tractor should charge the battery as it runs if it was equiped with electric start the battery charger more than likely over charged it killing the battery
Jun 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Lawn mower will not hold charge with new battery sometimes starts sometimes no l 120 john dear mower I change my alternator, but it was not turn the fly wheel. what I did wrong
Often mowers come with batteries which simply do not have the cranking amps to do the job. Have someone look at your mower and see if your attery has the sufficient cranking amps.
May 28, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
LG 42PX5D 42 in. Plasma HDTV Logo
82 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
