The tray won't close and open properly, forced open and now can't close. What do I do? Need to close the DVD tray it won't close when the eject button is pushed.
The tray was stuck possibly from other items sitting on top and I forced it to get it started and now I can't get the tray to go back in.
Method 3 - Force Eject
Next, you can try to to force eject the CD/DVD tray to open. Not all drives and burners have this feature. To check to see if yours does, look near the face of the CD/DVD drive and you should see a small hole.
Use a toothpick, bent paperclip, or needle to push the button. This may or may not pop open the drive. Many people have reported that this does not work. But some have reported that it does.
or try this link.
by just resetting the software will not work this is a mechanical problem this usually happens on players that is not use for a long time or improper closing of tray..fixing this kind of problem requires opening the cover of the unit..you need to lubricate all moving gears and parts by putting enough amount of lubricating oil..you have also need to assist the motor manually by helping it to push the tray out just gently pull the tray with your hands during a eject command on the unit clean also the limit switches of the tray make that contact are properly working..good luck!
Just below the CD/DVD tray there is a tiny hole. Insert a straighten paper clip in this hole and gently push the paper clip until the CD/DVD tray pops out. You can now pull the tray out until it is in the fully opened position to remove the disc. Try pushing the eject button to see if the tray closes, then push the eject button to see if the tray opens. If this foes not work then the CD/DVD drive is faulty and it needs to be replaced.
What could be done is to leave the set Switched ON for many hours even overnight and see how it can change if there is a possible fault on the motherboard, a change of value in electrolytic capacitors. If there is no result then there is fault in the motherboard and you need to take consensus for an estimate.
If you are trying to eject a disc, look closely at the front bezel of the drive, there is a small hole near the eject button, push a paper clip into the hole (straightened paperclip) and the tray will be ejected.
If the DVD door is stuck and will not open through ejecting via the icon in My computer, or the eject button on the bezel will not work, you likely have a faulty drive that will need to be replaced
Mechanical
timing and alignment is the problem of your dvd player. This comes when you accidentally force the disc tray to close. You need to
open the cover of the dvd player..take out the dvd mechanical loading
system try to eject it manually by turning the gear with your
hand. Make sure that the cd loader reaches the limit switch before it
closes. This will return back the right timing and alignment.
Do you mean the CD tray won't stay closed? If so check the simple things first. The button that you push to open and close the tray is actually a lever that pushes a much smaller button below it. Make sure that your eject button is not stuck down for some reason. Check your cd tray and the bay to make sure nothing got inside that is preventing the cd tray from closing all the way. I believe if something gets in the way the tray will automatically re-open. You can also take some compressed air and blow out the cd tray to remove any debris that may be blocking the tray from closing.
If none of the above simple steps work I believe it boils down to 2 things. 1. An object inside the case or tray that is preventing it from closing all the way or...
2. The eject button is stuck down.
If your comfortable with it you can take apart your xbox case and remove your CD/DVD player and ensure the button works properly. You can do a search on this site or youtube for instructions on how to take the case apart if needed. Once the case is apart the CD/DVD player is easily removed. You will then notice that the switch you press on the outside of the Xbox to open and close the CD/DVD tray is actually a lever that presses a much smaller switch directly on the front of the CD/DVD unit. You can then test your eject switch directly by pressing the button directly with a ball point pen or a pin. If the bay does not open and close properly at this point it may be necessary to replace the CD/DVD player and I do not know if it can be replaced or not. Hope this helps.
You may force eject the CD tray by inserting a paper clip inside the small slot or you may force restart your computer by pressing the power button for 5 seconds.
put the machine in standby mode (ie switch power button on machine or remote) then, press and hold the STOP and CHANNEL UP buttons simultaneously. This will force the disk tray to open.
