Question about Video Cameras
Need to know the right kind of cable to connect it to my tv.Thanks.
I could not find a manual for that specific one, however I did find this: http://www.ebay.co.uk/itm/JVC-VIDEOMOVIE-GR-AX10-CAMCORDER-VHSC-VHS-C-/380362198096 You may contact them and see if maybe they would make copies of it and send them to you for a minimal fee?
Posted on Sep 17, 2014
Testimonial: "I'll try your suggestion, thank you!"
SOURCE: What cable do I need to hook up Video camera to pc?
Try Firewire Cable ....but check that your Camcorder as well as the PC has the port ..... If not then check S-Video Cable
Posted on Oct 16, 2008
SOURCE: need manual for using the JVC GR-AX201A compact VHS camcorder
Please download user manual of GR-AX201 from JVC Support.
Posted on Nov 27, 2008
SOURCE: WE NEED THE OPERATING MANUAL FOR THE JVC COMPACT
The operating manual could be downloaded from here
http://resources.jvc.com/Resources/00/00/91/LYT1519-001A.pdf
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!
Posted on Jun 16, 2009
SOURCE: I want to join my JVC Compact VHS GR-AX2 from the
You cannot connect an analog camera to a USB port. The signals are completely different. There are no cables available to join these incompatible connectors together.
However, you can get videos from this camera, or any analog video source, into a computer. You just have to play them into an analog interface port. These are available as expansion slot cards for a PC. They will come with software to digitise the video input and record it to a file. You don't need any "driver" related to the camera, it is just a video signal. The connecting leads will be standard RCA signal plugs, like on the back of a HiFi amplifier. You probably already have a lead for this.
Posted on Oct 31, 2010
Testimonial: "very prompt response. not being too computer savvy i'll take time to digest the answer and implement. definitely helping me to move forward. thankyou."
SOURCE: i have a jvc compact
http://www.amazon.com/Maxell-290060-Mechanical-VHS-C-Adapter/dp/B00012F6A6
Go to the above link to find this part from Amazon.com, it is also available at Wal-Mart, Best Buy, Radio Shack or other online vendors. Cost should not be more than $15. It is called a VHS-C adaptor cassette.
Posted on May 04, 2011
Most major manufacturers supply manuals
online so if you were to log on to the manufacturer's web site, you
may be pleasantly surprised as usually, if available, one is able to
download, by model number, Customer
Instruction Manuals, Dealer
Network for spare part supplies and
Driver
downloads
(if applicable)
as required.
The information is normally free of
charge.
I hope this helps.
