Will not play tapes
SOURCE: Technics RS-TR272-no sound during play
CHECK CONNECTIONS AT THE BASE OF THE READ HEADS AS THEY HAVE A TENDENCY TO CRACK OVER A PERIOD OF USE. CAREFULLY STRIP BACK AND RESOLDER, REMEMBER TO LEAVE SOME SLACK AS THE HEADS REVOLVE ON TAPE REVERSAL.
SOURCE: RS-dc10 DCC replacement head
You should contact Panasonic, or Matsuchita. They can most likely give you their authorised parts dealer. You may find the head to be a little expensive.
You will have to have an experienced tech install the head for you. He will have to do a tape path alignment with the frequency response calibration.
Jerry G.
SOURCE: Technics RS-TR373 is chewing tapes
A lot of tape chewing problems are caused by the capstan roller being worn. Check for wear or oxide on that first.
SOURCE: I need to know how to record 1 tape onto another
press the synchro start button, the tape deck should now go to REC PAUSE, press the SPEED button till you get the required recording speed then press the synchro start again and it should start to record from deck 1 to deck 2.
make sure the tabs at the top of the tape you want to record on are intact,
if not just put a bit of sticky tape over holes.
hope this helps?
SOURCE: tape deck not working on a technics rs-eh600
My tape deck is not working. When starting play it goes forward and then reverse. What can I do?
