Some how your phone was reset or had the tone turned off. Just follow the below guide and your audio should come back on. I would do a soft reset (turn off the handset, remove the battery then reinsert) before performing the instructions.
Tone settings To select a ringing tone for voice calls, select Tones > Ringing tone. To select a ringing tone for video calls, select Tones > Video call tone. To set the ringing type, select Tones > Ringing type. You can also set the device to sound a ringing tone that is a combination of the spoken name of the caller and the selected ringing tone, when someone from your contacts list calls you. Select Tones > Say caller's name. To set the volume level of the ringing tone, select Tones > Ringing volume. To set the various alert tones, select Tones > Message alert tone, E-mail alert tone, Calendar alarm tone, or Clock alarm tone. To set the device to vibrate when you receive a call, select Tones > Vibrating alert. To set the volume level of the device keypad tones, select Tones > Keypad tones.
I have included a link to download your user manual if needed, it comes as a PDF file so you need to have adobe PDF down loader
Dear Sir .
Currently your mobile ringing tone is set at low ringing volume level.Thats why you are facing this problem.To increase your ring tone sound follow these step :
Select Menu > Settings > Tone settings and from the available
options:
Select Ringing volume . Set Ringing volume to level 2 or above, your phone rings with the volume ascending from level 1 to the level for incoming calls.
I hope this will works for you.
Regards.
Rizwan.
This simply means that the alarm tone you are making use of is not loud enough to alert you at the appropriate time.
What you need to do is to make a change of the alarm tone from your phone ringer settings, while doing this, make sure you click or select a louder ringing tone from the ringing tone setting.
with the above information, you will be able to increase the volume of our phone alarm to give you the appropriate alert when needed.
To mute the ringing tone instead of answering a active call,select Silence. or u can try the following
To set a mute ringing tone for a profile, select Options > Personalise > Ringing tone. Select a ringing tone from the list, or select Download sounds to open a bookmark folder containing a list of bookmarks for downloading tones using the browser. Any downloaded tones are saved to Gallery. To play the ringing tone for a selected contact group only, select Options > Personalise > Alert for, and select the option similar to none,etc...
menu 2 settings 3 tones incoming call alert (set to ringing) ringing tone ( pick your ring tone) ringing volume (set to level 5 loudest) vibrating alert (on) message alert tone (pick tone) instant message alert tone (standard) keypad tones (on) warning tones (on) this is for the alarm and ringtone this is where your problem is so double check these settings ok alert for (all calls)
Try the following instructions, to personalize your Nokia E50! Profiles Warning: In the offline profile you cannot make or receive any calls, or use other features that require network coverage. Calls still may be possible to the official emergency number programmed into your device. To make calls, you must first activate the phone function by changing profiles. If the device has been locked, enter the lock code.
Select Menu > Tools > Profiles. You can adjust and customize the ringing tones, alert tones, and other device tones for different events, environments, or caller groups. To customize a profile, scroll to the desired profile in the list, and select Options > Personalise. Define the following settings: • Ringing tone — Select a ringing tone from the list, or select Tone downloads to open a bookmark folder containing a list of bookmarks for downloading tones using the browser. To listen to the selected tone, select Play. If you have two alternate phone lines in use, you can specify a ringing tone for each line. • Say caller's name — Activate the text-to-speech ringing tone feature. When someone from your contacts list calls you, the device sounds a ringing tone that is a combination of the spoken name of the contact and the selected ringing tone. • Ringing type — Select how you want the ringing tone to alert. • Ringing volume — Select the volume level of the ringing tone. • Message alert tone — Select a tone for received text messages. Or you may still go to this website for more info! http://nds1.nokia.com/phones/files/guides/nokia_E50
hi!
check your mobile is in silent mode!
After that goto tone setting->ringing mode->you keep it is ringing->select alter for all calls->and than check volume!
or
Otherwise goto profile personalise setting tone setting->ringing mode->you keep it is ringing->select alter for all calls->and than check volume
Good luck
go to Profile in Menu select outdoor options- personalise set to------ Ringing Tone- any ringtone u want Ringing Type- Ringing Ringing Volume- Full Message Alert tone- any tone u want Vibrating Alert- on keypad Tones-__________ Warning Tones-_____________ Alert For-_________________ Profile Name-_____________
