Question about Danby Freezers
Brought a 3 cubic foot freezer that will not run
Brought a new 3' cubic freezer that will not run, only the motor heats up
Narinder Chhina
    New Friend:
  • 153 Answers
Call Danby or go back to where you brought will exchange
Posted on Nov 12, 2014
5 Related Answers
Anonymous
  • 12 Answers
SOURCE: bosch freezer
Condensor coil needs cleaning.
Posted on Aug 05, 2008
Anonymous
  • 13 Answers
SOURCE: breaker tripping?
It looks like your compressor is the problem , you can try to put a starting kit if it doesnt work you will have to change the compressor!
Francois
Posted on Jan 21, 2009
Anonymous
  • 7 Answers
SOURCE: what is the recommended temperature for the 14
at least 0 degrees
Posted on Feb 03, 2010
Anonymous
  • 113 Answers
SOURCE: Need Freezer gasket for 20
I would suggest you check with a local appliance parts warehouse. They will also have a service manual that you can purchase that will guide you.
Posted on Sep 22, 2010
rickyrt441
Richard Hale
  • 4399 Answers
SOURCE: 15 cubic foot chest freezer, new, plugged it in,
I wouldn't think this is right. If that is the case, it is not holding the temperature well then.
Posted on Feb 17, 2011
Will 3.74cu.ft. freezer hold 95lb of food?
Hi Trish:
1 cubic foot of water weighs 62.4 pounds so if you had 3.74 cubic feet of water (not frozen) it would weigh just over 233 pounds.
Most of the frozen veggies you put in a freezer have air space and the specific gravity (weight per cubic foot) is quite a bit less than water. Meats are closer to the same weight per cubic foot as water, but you still have air spaces between the packages.
I'd guess that you could get 95 lbs of food in it but you would have to pack it very carefully.
May 18, 2015 | Freezers
What is the cu ft for frigidaire upright freezer mfu21m3gw1
Thank you for your post, friend!
I see you would like to know the cubic footage of your Frigidaire freezer. Based off the model number you have provided it appears that you have a 21 cubic foot freezer. Hopefully this information is helpful. -Matt
Feb 20, 2015 | Frigidaire Freezers
Frezzer keeps icein over
Hello;
My name is Peter. I am a retired field service refrigeration technician.
There are several things to check:
1.) Door Gasket -Take a piece of paper. With the freezer door closed run the paper around the gasket. If you can do that, then you are not getting a good seal.
Repair: Clean the freezer door gasket with soap and water. While still wet, take a hair dryer and a spatula, going around the gasket, heat the gasket while pulling the gasket out to expand it.
Note: This only solves the problem if there is frost in the front area of your freezer.
2.) Freezer fan not working - In some cases, The freezer fan helps to prevent warm air from getting into the freezer.
3.) Food Storage - Make sure you do not overload the freezer, and that the food product is inside the bounds of the racks.
4.) Fresh Food Section Air Vent Wide Open - This is your probable cause: Heat goes to Cold like a magnet. When you open your fresh food section door and then close it you are forcing warm air up the vent that goes to the freezer. You probably have a broken air vent assembly.
Oct 08, 2014 | General Electric Top Freezer 21.0 Cubic...
My frige stops working after 3 days of running
What does the timer power? If it's a heater that defrosts the coil, check that.
May 11, 2014 | General Electric Top Freezer 21.0 Cubic...
Cubic feet for Frigidaire Chest Freezer MFC13M4FW3
Good Morning, thank you for your question! This particular unit is a 12-13 cubic foot freezer. If you have further questions, please do not hesitate to reconnect.
Jul 20, 2013 | Frigidaire 5 cu. ft. / 142 liter Chest...
Breaker tripping?
Francois
Nov 14, 2008 | Freezers
Freezers Logo
132 people viewed this question
Top Danby Freezers Experts
Dennis Boxerman
Muntejaya Ginting
Muntejaya Ginting
Willie Cooper
Willie Cooper
Are you a Danby Freezer Expert? Answer questions, earn points and help others
