Question about Lenovo Computers & Internet
How do i sync my keyboard to my laptop?
I received a Lenovo keyboard KBRF3971 and I can't figure out how to sync it to my laptop. I didn't get a clip with it like the mouse has.
5 Related Answers
Anonymous
  • 150 Answers
SOURCE: cannot connect wireless keyboard and mouse
I am assuming that this is an INFRA-RED device, with
plug and play capability.
1) Make sure that the infra-red port is turned ON on your PC,
in the BIOS and in Windows (using control panel)
2) Make sure that the infrared driver is working:
My Computer ==> Right Click ==> Properties ==>
Hardware ==> Device manager ==> ....
Find the Infra-red device and check its status.
Some laptops have a mechanical switch witch controls all
wireless ports. If you shut-off the Wi-Fi, the blue-tooth and
the infra-red will also be disabled.
3) Check for tiny reset buttons on the keyboard, mouse and
the receiver. Press them repeatedly.
4) If the device is communicating, and infra-red ICON
should appear on you taskbar (RHS).
Right click the icon and make sure you enable IR
communications AND plug and play.
5) Make sure you have installed any drivers that came with
the keyboard, if any.
6) Again, make sure that infra-red communications are enabled
in the control panel.
5) Failing that, it is possible that the keyboard is defective,
or the infra-red port on your laptop is NFG, it would not
be the first time.
6) You may want to take your keyboard to a computer
shop, and ask the staff the try it with a different PC.
Alternately, try a different keyboard with the laptop.
Martin
Posted on May 08, 2008
Anonymous
  • 21 Answers
SOURCE: Troubleshooting keyboard and mouse
i think u did'nt set ur blue tooth configration....pls set ur bluetoooth configration an try this again ...
Posted on Sep 20, 2008
MUKHTAR
mukhtar21 shaikh
  • 2022 Answers
SOURCE: Logitech mouse n keyboard wont connect
whenever you chage the battery you have to syncnonize your keyboard and mouse to sensor of the reciver. you can see on the back side of the keyboard there is connect button just press it and on the recevre side also press the connect buton same setting do with mouse also.
Posted on Sep 08, 2009
miznye45
  • 19 Answers
SOURCE: micro innovation intelligent wireless keyboard won't sync
Look on bottom of the keyboard, it should have a real small switch giving you the options of chanels. Try another setting then press the button on top of the transnmitter to have it look for it again on another chanel.
Posted on Dec 22, 2009
kdgaydos
kdgaydos
  • 22 Answers
SOURCE: mouse connects but keyboard doesn't.
Your keyboard should have some type of button on the bottom that "resets" it. Your keyboard has bounced to a new channel that is not recognized by the reciever. I kept having this problem so now I use a wireless mouse but, a corded keyboard.
Posted on Aug 15, 2010
My Lenovo laptop types symbols when I type figures. I also need to use caps when I need uncapped text and visa versa. Can you please help
sounds like your keypad is not set up right try going in to control panel and click on keyboard and try to set from there.
Oct 08, 2016 | Lenovo Essential G500 Laptop Computer -...
How do you get the lenovo ultraslim keyboard model KBRF3971 CapsLock on/off indicator to display on the screen?
This function is driven by a Lenovo driver for the screen. This is not easily removed. If you were to uninstall all Lenovo drivers that would do it, but it would also remove other Lenovo functions like the volume level indicator on the screen and the Lenovo button, etc.
Oct 21, 2015 | Lenovo Computers & Internet
On my Lenovo g500 laptop many keys(gh and many) are not working, what should I do?
Connect to external usb keyboard to check. If works ok, your keyboard is defective and you should change it.
See tutorial
How to replace or remove keyboard on Lenovo G500 keyboard replacement
How to replace the keyboard of Lenovo g500 g510 g505
LENOVO G550 Keyboard Installation Replacement Guide Laptop Remove Replace...
Lenovo G580 G570 G500 G510 disassembly replacement keyboard hard disk full...
A warning: might look easy but if you are not really familiar with dismounting a laptop, you might end taking your device to a repair shp in a shoebox.
Jul 20, 2015 | Lenovo Computers & Internet
Lenovo yoga keyboard not working after Microsoft sign-in
go to bios sistem and resore all this from default and try again coment please !
Apr 02, 2014 | Computers & Internet
Remove dent
IBM/Lenovo ThinkPad R61 Notebook PC >
Bottom Case Cover, (Base Enclosure),
http://www.ebay.com/itm/NEW-IBM-45N4073-Lenovo-Thinkpad-R61-15-4-Bottom-Case-Base-Cover-42W2231-/360642073440?pt=US_Laptop_Housings_Touchpads&hash=item53f7f15360
Keyboard/Palm Rest Cover Bezel,
http://www.ebay.com/itm/IBM-ThinkPad-T61-T61P-R61-14-1-upper-keyboard-palmrest-bezel-cover-42W2466-/400491727269?pt=LH_DefaultDomain_0&hash=item5d3f2ac9a5
Palm Rest Cover,
http://www.ebay.com/itm/Palmrest-Assembly-Cover-IBM-Lenovo-ThinkPad-R61-R61i-14-1-Laptop-/281030800308
Not advertising for seller nor website. Just examples.
Here is the free HMM from Lenovo Support.
It is the Hardware Maintenance Manual. The Service Manual.
Shows and details how to replace the above parts,
http://support.lenovo.com/en_US/detail.page?LegacyDocID=MIGR-67760
Also USE an ESD wrist strap, and have it's alligator clip attached to a good ground source.
Here is an average example,
http://www.radioshack.com/product/index.jsp?productId=2103245
For additional questions please post in a Comment.
Or click on Reply at end of solution, and post.
Regards,
joecoolvette
May 19, 2013 | IBM Lenovo ThinkPad R61 Notebook
BATTERY OPERATED KEYBORD. HOW TO TURN ON POWER.
You need to sync the keyboard to the dongle. Power switch should be on back with sync button.
Dec 15, 2012 | NexxTech High Quality 2.4ghz Wireless...
Sl510 keyboard and mosuse not working; on screen keyboard and remte mouse works. Any recommendaton?
You will need to replace the keyboard, but since there is a mouse problem also, I recommend the laptop be checked for motherboard damage by a computer repair shop. What ever moisture got in will need to be cleaned up.
Jul 08, 2012 | IBM Lenovo ThinkPad SL510 Notebook
Laptop button fell off my lenovo y510
I have the same problem on my lenovo laptop. Apparently it needs a new keyboard completely which is £70 dianogis charge, £212 labour charge plus parts plus vat as a keyboard is not covered by warranty!!!
Oct 10, 2009 | Computers & Internet
Replace keyboard on Y510
OK, Here is the official Lenovo Service Manual for every component on the Y510.
http://consumerdl.lenovo.com.cn/UserFiles/UserGuide/en/User%27s%20guides%20and%20manuals/Y450/Lenovo%20IdeaPad%20Y450%20Hardware%20Maintenance%20Manual%20v2.0.pdf
However, removing the panel above the keyboard is not as simple as just removing the 4 screws located in the battery compartment and the three along the back edge on the bottom. Yes there are some "L" brackets on either end that are a pain to get to let go, but I found that by removing the DVD drive and removing the screw in the bay edge closest to the top panel, it helped loosen things to remove the top bezel. You may have to use a small flat blade screwdriver to pry the front edge up by the PF keys. Be careful removing the top bezel though, there are two small electrical ribbons attached to it for the volume and other controls. Once you have the top bezel ose, you simply have to lift the top edge of the keyboard and release the connector ribbon by flipping up the front edge of the connector. the manual illustrates this. Then it's just a matter of reversing the order. Reassembly is must easier and faster than disassembley.
Mar 08, 2009 | Lenovo IdeaPad Y510 Notebook
Computers & Internet Logo
142 people viewed this question
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
