Question about Samsung Dp700a3b-a01us Touch Desktop All-in-one Pc Touchscreen 6gb 1tb
How do I change ram on a Samsung DP700A3B-A01US?
Need to change ram in all in one and I don't know where it's at or how to get to it
Randy Bitner
    New Friend:
Not much information out there for the Samsung DP700A3B-A01US which I have. First of all, not easy, but can be done. First turn the monitor to 90 Degrees, turn upside down on a counter so you can see bottom, with monitor over edge of counter. Their are several screws in the corners holding grip molding in place. Remove all screws. Four screws will be very short screws where the monitor hinges. I used a butter knife starting in the back behind the DVD space is a split in the plastic edge. Start there, pry slowly. Tilt from black bottom away from computer. You can now see the tab holding split in place. Now continue working to your right, around corner. I had lots of trouble with the mic area. Once you are past that area, start same process to the left, always tilting away from the base. The plastic strip will start coming loose. I had lots of problems at the DVD area and broke two tabs. Now the whole surround will come off. This took me about 15 minutes. Step 2, pulling from back, lift up on the metal, towards DVD player. There are two metal tabs at DVD player that found stubborn. Pull the metal base off. You now have access to the RAM, HARD DRIVE and DVD. CLEAN inside now. My dvd player is bad. This is a proprietary DVD, not sure if I will find one. But this the process to get to the guts of this computer. I went out and bought an LG DVD player to connect to USB. Take your time, it can be done. My computer is 2011 plastic is hard and brittle. You can do it.
Posted on Jan 27, 2019
Hello I was wondering what is the best cpu for this Laptop. All i have is a P4600 celeron, I cant find information about the motherboard from samsung. I presume the motherboard is a BA92-07852A.
I have chatted to a guy Dinoop P from Samsung support.
He could only confirm that max mem was 8GB. He said CPI couldn't be upgraded, but referred me to buy the Repair Manual from their outlet, which is also known ad J&J
CPU world says "
Q: Can I upgrade my Celeron P4600 microprocessor? A: Probably yes. Processor compatibility is determined by your motherboard. Please check CPU-Upgrade.com resource for CPU support list for your board."
on
Intel Celeron P4600 Mobile processor CP80617005307AB
and at the bottom of that page lists CPUs which physically fit into the motherboard, and are electrically compatible with the CPU socket. This does not mean they are compatible with the m/b (though it likely that some are). You might find a post in a forum somewhere )like the Samsung forum) describing a successfully upgraded CPU
Jul 10, 2015 | Samsung NP200B5A-A01US - Series 2 Business...
NP350E7C-A01US samsung laptop windows 8 keep shuting down after 5 mint or some time 10 mint .
are you sure the cooling fan is working . sounds like a overheating problem t me
Feb 28, 2015 | Samsung Computers & Internet
Samsung access
Can you right click the screen
Aug 27, 2014 | Samsung 700a Dp700a3b-a01us Intel System...
How do I unlock the HDD Password ?
Short answer: without the password, you cannot wipe it.
May 19, 2014 | Samsung 23" Touch-screen Series 7...
Replace Hard Drive
Desktop and laptop differs. Be more precise.
Apr 30, 2014 | Samsung Dp700a3b-a01us Touch Desktop...
Samsung NP900X1B-A01FR Ram slot
Most likely you will have to remove the keyboard to access the memory slots. I don't know why they do that. Most manufacturers have an access panel on the bottom for ram.
Feb 09, 2014 | Samsung Notebook NP900X1B-A01US 900X1B-A01
Updates won't load on Samsung DP7003ab
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Jan 02, 2013 | Samsung Dp700a3b-a01us Touch Desktop...
Samsung Dp700a3b-a01us Touch Desktop All-in-one Pc Touchscreen 6gb 1tb Logo
755 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
ThaMp3Doctor
ThaMp3Doctor
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
