Question about Canon PIXMA iP4200 InkJet Photo Printer
Trouble with ink
New black carthrige when inserted lights up when lid closes i get low ink and light is out and it won't print.
Posted by 4clem on
  • bubico Dec 27, 2007
    I have the same problem. I use only original cartridge but the Black is not recognized by the printer. When inserted, the light remains off and the message on the screen indicates that the printer is out of black ink.
Pookeybrain
  • 51 Answers
Most Canon inkjet problems can be resolved by replacing the print head. eBay is the place to look for a replacement.
Posted on Nov 10, 2007
How do i change my lexmark x4650 print cartrige?
Installing/Replacing your ink cartridges:
1. Open the printer, and then press down on the cartridge carrier levers. printmastert_52.jpg
2. Remove the used print cartridge or cartridges. 3. If you are installing new print cartridges, remove the tape from the back and bottom of the color cartridge, insert the cartridge in the right carrier, and then close the color cartridge carrier lid. 4. If a black cartridge is included in the box contents, remove the tape from the back and bottom of the black cartridge, insert the cartridge in the left carrier, and then close the black cartridge carrier lid. 5. Close the printer.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
May 15, 2011 | Lexmark X4650 InkJet Printer
Just need to know how to put in black ink in the z1300
Follow these steps on how to install the cartridge: 1. Make sure the printer is on. 2. Lift the access cover. The print cartridge carrier moves and stops at the loading position, unless the printer is busy. 3. Press down on the left cartridge carrier lever to raise the cartridge carrier lid. 4. Remove the used print cartridge(if you are replacing). Insert the new black cartridge in the left carrier. 5. Snap the lid closed.
3. Remove the used cartridge.
4. Load the new black cartridge. Close the cover.
Apr 29, 2011 | Lexmark Z1300 InkJet Photo Printer
I need to know where the ink cartridge goes on my x6575 what cartridge goes where
1.Turn on the printer.
2. Open the printer by grasping the printer's top lid, to the left of the control panel and just below the scanner cover ,( approx. 1 inch ) to expose the ink cartridges.
3.Press down on the cartridge carrier levers.
4.Remove the tape from the black print cartridge, insert it in the left cartridge carrier and close the lid.
5. Remove the tape from the color print cartridge, insert it in the right cartridge carrier and close the lid.
6. Close the printer.
Your ink cartridges are installed.
Feb 17, 2011 | Lexmark X6575 All-In-One InkJet Printer
How do you load new printer cartriges
To replace an ink cartridge using the fonth.gif ink button, follow the steps below.
1. Make sure that the printer is on. The fontp.gif power light should be on, but not flashing.
2. Lower the output tray, then open the printer cover.
3. Press the fonth.gif ink button. The print head moves to the ink cartridge replacement position, the fontp.gif power light begins to flash, and the fonth.gif ink out light corresponding to the ink cartridge that needs to be replaced begins to flash or remains on.
4. Open the cartridge cover. Pinch the sides of the ink cartridge that you want to replace. Lift the cartridge out of the printer and dispose of it properly. Do not take the used cartridge apart or try to refill it.
5.Remove the new ink cartridge from its protective bag. Place the ink cartridge vertically into the cartridge holder. Then, push the ink cartridge down until it clicks into place. Do not apply excessive force to the cartridge.
6. When you are finished replacing the cartridge, close the cartridge cover and the printer cover.
7. Press the fonth.gif ink button. The printer moves the print head and begins charging the ink delivery system. The fonth.gif ink lights start flashing. This process takes about one minute to complete. When the ink charging process is finished, the printer returns the print head to its home position. The fontp.gif power light will stop flashing and remain on, and the fonth.gif ink out light will turn off. The fontp.gif power light will continue to flash while the printer is charging ink. Never turn off the printer while this light is flashing.
Nov 19, 2010 | Epson Office Equipment & Supplies
How to load a MP130 cartridge?
  • 1 Turn on the printer and check the LCD screen for an indication of which ink cartridges are low. Note that recycled ink cartridges sometimes read "Ink low" even when they still have ink, so print a test page if you're not sure.
  • 2 Expose the ink tray by lifting the entire LCD control panel, which is attached to the underside of the copier tray.
  • 3 Pull out the used ink cartridge by pulling straight up from the print head,
  • 4, insert the new cartridge into the print head and push down until you feel a click. Close the printer lid and let the printer reset the ink tray.
  • 5 Print a test page to make sure the new ink works. If it doesn't, you may have forgotten to remove the protective tab under the cartridge.
  • Nov 13, 2010 | Canon PIXMA MP130 All-In-One InkJet...
    How to Change ink cartridge on Epson Stylus SX215
    #1 Wait until you are out of ink. The warning light and ink-low notifications come on well before the ink cartridge is empty, and even if it runs out of ink in the middle of a print, you can replace it then and finish the print with no problem.
    #2 Lift the lid of your Epson inkjet printer to expose the ink cartridge replacement button. Make sure you have plenty of light so you can see what you are doing.
    #3 Press the ink cartridge replacement button. This will loosen the empty ink cartridges so they can be pulled up and out.
    #4 Fill the empty cartridge at an ink-refilling location, or buy a new ink cartridge to replace the empty one.
    #5 Insert the new or refilled ink cartridge into the holder with the same orientation as the previous one.
    #6 Press the cartridge replacement button to charge the system and close the printer cover. Charging takes about one minute
    Thanks
    Sep 30, 2010 | Epson Stylus Multifunction Inkjet Printer/...
    After installing re-filled ink cartridges, both color and back & white, the printer message that shows ink level still shows low level ink? How do we resolve?
    Try this procedure:
    1. Open printer lid so cartridges move to center of carriage.
    2. Lift clamp and remove black or color cartridge from the holder.
    3. Place cartridge on table with copper contact strip facing you.
    4. Carefully place a strip of clear plastic tape over the four contacts on the upper left corner of the cartridge.
    5. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position.
    6. Open lid and remove cartridge again. Remove tape from left side and place tape over four contacts at upper right corner of cartridge.
    7. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position again.
    8. Open lid again, remove cartridge, remove tape.
    9. Reinstall cartridge and close lid.
    Printer will now recalibrate. Once the process is complete the ink level meter should be reading full again.
    I hope this helps, if so please rate our solution.
    Buddy
    Corporate Computer
    www.ccl-la.com
    Dec 22, 2009 | HP Hewlett Packard Deskjet 5650 InkJet...
    Changing ink carthrige
    hi try to clean the contact point of ink and ink carrier.if it's not work 2 thing you need to consider....
    1.maybe your ink is not compatible or not detected..
    2.maybe your ink carrier is most likely defective.
    hope this would help you...
    Oct 27, 2008 | HP DeskJet 820cxi InkJet Printer
    HP Deskjet 6940 not printing after replacing ink cartridge
    My HP Deskjet 6940 is not printing. The color (left) low ink light is dark and the black (right) low ink light is flashing. I replaced the black ink cartridge with a new one but the low ink light continues to flash. No tears/rips in the circuit strip and all the copper leads appear to be connected
    Sep 29, 2008 | HP Deskjet 6940 InkJet Printer
    Orange light blinking
    Solution: Confirm the ink tank(s) are properly installed iP4300
    Ensure that the ink tank is installed properly. Open the Top Cover, Paper Output Tray and Inner Cover, and then press on the 'PUSH' mark on the ink tank whose lamp is off until the ink tank clicks into place. Once the ink tank is installed properly its lamp will light red.
    Ensure that all the orange tape has been peeled off as shown in (1). If a part of the orange tape remains as shown in (2), remove it completely.
    (1) Correct (An L-shaped notch* appears on the ink tank.)
    (2) Incorrect (Orange tape remains. Peel off the tape along the perforation.)
    Nov 02, 2007 | Canon PIXMA iP4300 InkJet Photo Printer
    Canon PIXMA iP4200 InkJet Photo Printer Logo
    old marine
    old marine
    Muntejaya Ginting
    Muntejaya Ginting
    Ekse
