I am looking for were the ECM is located in this vehicle and what it looks like.
SOURCE: O2 sensors on 2002 buick rendezvous
hi im wes the o2 sensor is always in the exaust newer buicks have one before the converter (sometimes in the exaust manifold) one after the converter if it has duall exaust it could have four
left bank sensor one is before the converter on drivers side bank two sensor 2 would be passanger side after the converter does this help?
SOURCE: location of blower motor control module
Its just above the blower motor on passenger side on housing. Goes in from the top side hidden, by cover on firewall.
SOURCE: try to locate body control module on a 94 buick park ave
BCM --The Body Control Module is located on the right side of the vehicle and positioned under the instrument panel. In order to gain access to the module, it will be necessary to first remove the trim panel.
SOURCE: 2002 Buick Rendezvous alternator removal
To get the alternator out, I had to move that large electical fuse / relay box out of the way,and remove washer bottle and battery. then use a 3/8" drive ratchet to move the tensioner forward to get the belt off. I used a small mirrow to get a view of the back bolts on the alternator and removed them.[ I used meteric # 15 open end & closed end combo wench. Keep turning the back bolts until the alternator become loose.]
SOURCE: What is cost to repair transmission and transfer
I just did this job on one of these at my shop and I charged 1600
Step
Action
Yes
No
Schematic Reference: Instrument Cluster Schematics
Did you perform the Diagnostic System Check - Vehicle?
Go to Step 2
Go to Diagnostic System Check - Vehicle in Vehicle DTC Information
Does the VSS parameter match the speedometer display?
Go to Step 3
Go to Step 4
Does the odometer operate properly?
Go to Testing for Intermittent Conditions and Poor Connections in Wiring Systems
Go to Step 4
Replace the instrument panel cluster (IPC). Refer to Control Module References in Computer/Integrating Systems for replacement, setup, and programming.
Did you complete the replacement?
Did you correct the condition?
Go to Step 5
5
System OK
Go to Step 2
