Question about Tablets & eReaders
My trio stealth 8 keeps resetting it self to defult setting what can i do to fix
Posted by evee on
Mark Davidoff
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 20 Answers
Try doing a factory reset. It can be done from the setting menu usually, or via a special button combination. Google will help you if you google your model number and 'factory reset'
Posted on Sep 16, 2014
3 Related Answers
naazirnizam
  • 37 Answers
SOURCE: My trio stealth-8 is frozen I can get it to the home screen
try rebooting by pressing the power button and volume up or down button for about 10 sec
Posted on May 28, 2014
SOURCE: When I get my trio stealth-9 if shows first two
Hi, u will need to take it in for repair on the software....
Posted on Jun 21, 2014
Thomas Smithbrother
  • 3698 Answers
SOURCE: Trio stealth-10 touchpad only works half way
www.samsung.com/us/support
https://support.google.com/android/?hl=en
Posted on Jul 02, 2014
My trio stealth- 8 powers on but won't boot up and the reset button just keeps powering it off what can I do to fix my tablet?????
One of the common solutions from YouTube videos short of more drastic measures would be to hold the power button for 10 seconds.
The below videos may help or will if you must resort to a hard reset - that will wipe all files and restore to original.
3 RESET WAYS on ANDROID TABLETS REVIEW 2nd n/a (pattern lock) Android Tablet stuck on boot screen Bypass it in easy steps Android tablet stuck on Android Logo Fix
Dec 29, 2014 | Tablets & eReaders
How to fix trio stealth g2 stuck on boot ?
turn it off. if you can't then their is a reset button on the side where the charger is. Get a safety pin put it in the hole. You will know if you reset it. It will reboot. It won't effect your files or info. I hope this helps!
Jul 01, 2014 | Mach Speed Trio Stealth G2 Tablet -...
I have a Trio-Stealth G2-8 and turn on but the screen said @9 Dual Core and don't do anything else can somebody tell me how to fixed?
Its a common problem with tablets and not easy to fix.
Your tablet has a corrupt os and is caught in a boot loop.
There are fixes but not easy for a beginner.
Boot into recovery mode by pressing the power button and holding the down volume button in then select restore tablet from the recovery menu.
Jun 12, 2014 | Mach Speed Trio Stealth G2 8 inch Tablet...
How to reset a trio stealth g2
If you can power it on go into settings then backup and reset. This will reset tablet to the out of the box status. You will loose all of your data. If it will not power up, press power and volume up while booting till the screen comes on.Boot options will come up then reset. Be sure the tablet is fully charged.
May 28, 2014 | Mach Speed Trio Stealth G2 8 inch Tablet...
My trio stealth g2 hype 4gb tablet will not go pass the trio stealth g2 logo it just freezes up what can i do
Have you tried my old trick of pressing the on/off button and at the same time, press the volume+ button. Sounds like you have a screen freeze. hope it helps.
LindaSView
Apr 24, 2014 | Mach Speed Trio Stealth G2 8 inch Tablet...
How to restart a trio stealth G2
all that shows is trio stealth G2 when turned on it freezes I tried the reset button
Jan 07, 2014 | Trio Stealth G2 7 inch Tablet with 8GB...
Trio stealth charging issues
The internal battery may be unable to recharge.
Jan 29, 2018 | Mach Speed Trio Stealth G2 Tablet -...
Tablets & eReaders Logo
141 people viewed this question
Top Tablets & eReaders Experts
Marvin
Marvin
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
