How do I fix?
I loaded paper into my HP OFFICEJET 4622 then hit print, sounds like its trying to work but then it says out of paper. I continued to add more paper but it says the same thing
Posted by Candice Adams on
303 Electronics
  • Office Equip... Master
  • 345 Answers
You just need to clean the paper pick up rollers. Common problem on this model printer, but very easy to fix. See video:
Posted on Aug 23, 2019
bvmihai
    Habit-Forming:
  • 168 Answers
Hi ! You can try to clean the pick up roller.
Posted on Sep 16, 2014
Will not print
more information please- have you tried re-installing the printer driver to test your data connection to the printer?
Jan 16, 2014 | HP Officejet 4622 Multifunction Inkjet...
My HP Officejet Pro K8600 prints crooked, how do I fix that?
is the paper going thrugh crooked?
make sure the paper is in the tray and the guides are night and straight.
if that is ok, look for something that makes the paper turn crooked by hitting it, such as a lost scrap of paper or a paperclip where it does not belong.
Dec 29, 2010 | HP OfficeJet Pro K8600 Printer
I am printing postcards which get stuck in the printer during the last 2 inches of printing. What can I do to fix this? The printer is HP officejet 6110 all-in-one.
How stiff is the card stock? Some cards cannot feed if the printer rolls the card to print on it. (This one does)
I have taped cards to a full size sheet of paper and run that through.
Usually this means the paper is too stiff.
You can try cleaning the paper feedroller with a rag with a bit of windex on it. (This roller is above the paper tray where the paper loads in.)
Apr 02, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Printer is loaded with paper but get message
Although you really haven't given me enough information, I will posit and response for you.
A "Load Paper Error can be caused by the application telling you to change the "TYPE or SIZE" of paper that is in your paper tray.
For example, The application thinks you want the page printed on "Letterhead" paper, but it know that you have plain bond paper installed.
So you are sent a change paper type message.
The fix is to hit go and skip around that error.
The actual fix is to make sure that your printer driver, application and the printer are all set to the same size paper and type paper.
Don
Nov 05, 2009 | HP Hewlett Packard LaserJet P1005 Printer
HP Officejet Pro L7800. Had paper jam, but opened
mine was 2 there was paper stuck in the little white gears
Nov 02, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Hp printers continue to jam
Print a self-test report Use the following steps to print a self-test report.
  1. Load plain white paper in the input tray.
  2. Press Setup , and then press 2 . The Print Report menu displays.
  3. Press 1 to select and print a Self-Test Report .
IMPORTANT! Try to print a self-test report after every solution even if the solution resolves the issue. Solution one: Clear the paper jam Follow these steps in the order presented to resolve the paper jam. Step one: Remove loose paper from the tray Remove any loose sheets of paper from the input tray and the output tray. CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism
Sep 08, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Printing both side of the paper using HP Officejet J5780 All in One
Make sure that you have the duplexing option turned on in your printer configuration. The "OK" button is right below the window that shows the date and time. Have a look here:
http://h71016.www7.hp.com/html/interactive/j5780/model.html?jumpid=in_r2910_3d/PDI/j5780%7Cshowcase%7Cflash
Jun 12, 2008 | HP Officejet J5780 All-In-One InkJet...
Paper Jam on
most printers are pretty cheap now so replacement is always an option....on the other hand, I will spend countless hours trying to figure out what is wrong first. Remove all paper first, open printer and check for pieces of torn paper or debris, if you have a can of air you can blow out the insides to clean. Put 3 or 4 sheets of paper in, print a test page and watch carefully how paper advances...is it straight or crooked when being loaded? Is printer trying to pull more than 1 sheet at a time? Good luck
May 14, 2008 | HP OfficeJet 7310 All-In-One InkJet...
HP Officejet 7130 xi all in one say Bad Print Head
printer flashes lightes and instructs to turn off and on. When ask to print
Apr 06, 2008 | HP Officejet 7130 All-In-One InkJet...
54 people viewed this question
Marvin
Marvin
