Razor MX500 Dirt Rocket Logo
A
Anonymous Posted on Sep 16, 2014
The bike runs constant even when the throttle in not engaged, does the throttle need to be replaced?
You can stop the bike, but then when you hit the throttle, it just keeps goinging even when you are not hitting the throttle, it is like a constant hot.
  • S morelli Nov 24, 2019
    A high idling engine on a dirt bike usually indicates a fuel or air pressure problem. When the engine idle suddenly runs high that usually means you've sprung an air leak, have a dirty air filter or you're running bad gas.Jul 3, 2018
jfbgm1
Level 3:
Master:
  • Master 706 Answers
  • Posted on Oct 17, 2014
jfbgm1
Master
Level 3:
Master:
Answers
706
Questions
0
Helped
166014
Points
1075
The cable may need to be adjusted, or the carburetor needs to be adjusted.
2016 Harley-Davidson Dyna Low Rider S (FXDLS) Electrical Issues I’m having some issues with my bike after I did a battery swap. Made the rookie mistake of crossing terminals After correcting the issue...
U may hav ruined a module by overcurrent or undercurrant when u took out batt. Maybe shudgit bike scand for codes. Make sure batt is 12.6 v..acoil ignition dont work well if value less. Buy a clymerbook for complete cycle repair
May 13, 2020 • Motorcycles
Basically I'm losing a lot of corner speed, when turning into corners. I shut the throttle off too early and it feels like I'm carrying the bike round the corner. If adjust the throttle mid bend,...
You need to accelerate very gently while you go round the corner. This sounds wrong but even if you hold the throttle in the same position, physics dictates that as you go round the corner you do actually accelerate as you go round a corner at a constant speed (velocity/direction/speed - look it up if your interested!).
So on the approach to any corner, you need to: -
1 Position yourself and the bike for the approaching bend, toward the right hand side of your lane for left hand bends and vice versa.
2 Adjust your speed to one you can quite happily ride around your bend (Slow down by easing off the throttle or appling the brakes)
3 Once at the right speed, (off the brakes) select the right gear for the speed your doing.
4 GENTLY apply some throttle to stop the bike slowing down anymore.
5 Tip the bike into the corner by gently pushing on the left bar for left handers or vice versa keeping the throttle still so that you hold your speed through the corner.
6 As the bend opens up (becomes a straight) gently apply more throttle as you release the pressure on the bar and stop turning.
If you want to keep improving your riding skills, sign up to a advanced riding course. They are for people who enjoy riding and want to be safer and consequently faster.
Good luck with your riding and enjoy!
How to drive?
you can ride the cluthch on a bike un like a car you wont hurt it its oil lubricated constantly, sitting on the bike pull the clutch in with your left hand and click the left foot lever down in to 1st, then learn how to click it back up 1 half movement in to neutral. the neutral light will come on sfter the bike enters neutral. in first gear give the throttle on the right hand a squeeze and pull the clutch in with your left hand put foot gear selector down in to 1 st and begin to release clutch slowly. hold on as bike will engage may be jerky balance yourself! when you get moving stop! by pulling the clutch in and the hand brake as you close the throttle to stop! practice your take off many times some where safe! when you get your balance in 1st gear pick up speed and begin shifting the foot gear selector up in to 2nd gear and practice closing the throttle and breaking to a safe stop. gears are generslly 1st down 1 click 2345 and6th all up from there and neutral is 1 half a click up from 1st between 2nd gear. And dont put it in gear with the kick stand down t may stall on you
hope this helps
Bike won't start, headlights and gauges light, hear a click coming from under the bearpaw, battery is new today from dealer
If you're hearing a clicking from the engine casing after changing the battery and the bike still won't start, chances are there may be a problem with your starter motor.
Either it's not contacting well enough to the battery (Faulty Wiring or Loose Connection), may be having trouble engaging/dis-engaging the starter gear, or it's just cactus and needs repair/replacing.
If you haven't tried push starting the bike, I'd suggest trying that first. Sometimes that can dis-lodge the starter gear if it's stuck, but it might require maintenance to ensure it doesn't happen again.
If you're un-aware of how to perform a rolling start, put the bike on a downward slope, or get a friend who can help push. Put the bike in first gear with the clutch in, and the ignition 'on' and roll the bike forward to a bit more than a brisk walking pace. Lift your weight from the seat and drop it down again quickly. As you drop down, release the clutch to engage first gear and hopefully the bike should spring into life. (Beware not to hold the throttle open, or stop moving too quickly, as this can cause an the bike to spring forwards or dropping of the bike as it stops suddenly)
If this fails, you may need to have the Started Motor removed to be looked at, as it may need replacing or repair by a professional.
Hope that helps!
Ran fine the other day, today i try starting it and itt turns over but then puts out, the accelerator hardly affects the running of the bike, i have to constantly twist the accelerator to keep bike...
You've either got some kind of contaminate in the float bowl or the jets are stopped up on your bike. If it runs as long as you keep twisting the throttle, it's run off the fuel from the accelerator pump. No fuel is getting through the jets. I'd take the fuel line loose and check the fuel flow. If your bike was made after 1996, you'll need a vacuum source to check the petcock as it is vacuum operated. I'd take the carb off and have it gone through as well. Check the vacuum hose that runs from the rear of the carb over to the VOES and the backside of the fuel petcock.
Good Luck
Steve
1helpful
Hello, i find it impossible to maintain a constant speed (about 30mph) without the bike juddering , im having to open throttle - close throttle constantly to keep at 30. it has been back for repair and...
Bikes like yours with high horsepower output, a high revving engine, and relatively light weight are very sensitive when operated at low speed - and at low power settings. I have found that usually, after getting well acquainted with a particular bike, things become much easier have a fine control over. In the meantime, try running in higher - or lower gear, at that speed. Sometimes that can make constant throttle movements less necessary.
Accelerator not responsive on the bajaj wave
This is because of the worn out clutch unit on your bike you need to get
serviced and clutch overalling on your bike and also need to get clean carb ,
to stop this problem ,if increase idling on your bike it give low mileage .
Few questions from a new owner
and I absolutely love it (aside from the broken headlight!) but I was wondering what the deal was with the seeming variations of paint finishes on the Military bikes? Mine and many others that I see have the flat olive drab finish, while there are others that I see with a very glossy finish, and in some cases, pinstripes. What's the deal with the variances -- are the glossy finishes and pinstripes the result of custom modifications? Also -- huge problem while riding. I know she's a brand-new bike (only 25 miles) so there are probably some break-in kinks that need to be ridden out, but this bike dies on me all the time. Unless I'm CONSTANTLY giving the bike throttle, it'll just die. Whenever I go to stop at a stop sign and am in first gear, the moment that throttle is let go, the bike just dies. It seems like I have to constantly pull the throttle on the bike to keep her running, it just does NOT want to idle. Also been noticing some small problems in shifting -- never seems to shift as smooth as other bikes I've been on, and I'm not sure if this is because it's a brand-new bike, or just older technology -- I'm totally new to all of this so I'm really not sure. Any ideas?,The shifting gets smother within 1000 miles, I have 1300 miles and rarely have any false neutrals or as clunky shift problems any more. Like Scotty said give the throttle screw a turn to increase idle( should turn by hand located on the carburetor). I did have a loose carburetor to cylinder head(jug) rubber boot loosen on me and was leaking air making the idle rough on my bike .After I repositioned the boot back on and tighten the clamp at the carburetor I never had the problem return.,,,
Top Razor Cycling Experts
ADMIN Eric
ADMIN Eric
vince
ADMIN Andrew
ADMIN Andrew
Are you a Razor Cycling Expert? Answer questions, earn points and help others
