JVC GR-D370 Mini DV Digital Camcorder Logo
Question about JVC GR-D370 Mini DV Digital Camcorder
My cassette is stuck is there a pin hole that I can poke to get it to come out?
I saw on another post there was a pinhole but I am unsure where it is exactly. Looks like the cassette area is popped up just a tad but the darn tape will not go in or out.
2 Related Answers
Anonymous
  • 11 Answers
SOURCE: Tape is stuck and will not pop out. I get error E01
The way I can get a tape unjammed on my Sony camera is to remove the battery, plug the camera into the AC charger that is plugged into the wall outlet. Then power the camera on, wait a few seconds. Then unplug the charger from the outlet, wait a few more seconds (camera still in "on" position) and then plug it back in. I have used this method at least 3 times to get the camera to release the tape and finally eject. However, the tape is usually pulled or stretched and I use a small flat head screwdriver to wind the tape back in, but expect that portion of the video to be ruined and I don't recommend using the tape in the camera again even if you manually wind it forward past the problem area.
Posted on Sep 09, 2009
Anonymous
  • 1812 Answers
SOURCE: Upon inserting the cassette tape
This is most likely a problem with one of the motor sensors and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Posted on Aug 06, 2011
Insignia flex android stuck in safe mode. powering it off did not help.
it has a pin hole reset find the pinhole an hold pin in for 15secs and it will reset as new
How to get a cassette unstuck
normally small pinhole on front that you can get a pin in to get cassette out
How to remove dvd stuck
Dear Renee,
Greetings from New Zealand! Not sure about laptops - but on a Desktop the DVD player has a tiny pinhole usually under/near the eject button. This is a manual eject & requires a straitened paperclip to poke in the hole which will mechanically release the DVD-drawer. Most service manuals warn that this should NOT be done too many times as it will eventually break the mechanism... I hope that this helps! GBU! - Bruce.
A pin hole lens cover for macro photography
Was this an attachment on the front of a lens, or simply a pinhole in place of a lens?
3helpful
2answers
I need to know how to open my stuck DVD plate in my desktop... please help
Hi, You can see a pinhole kindly try to pull it by using a pin or something
Please vote if you think this might help others:) Thank you
Have a gateway one. CD stuck and won't eject. There's no tray, no little hole to poke a paper clip into. How can I get it out?
wow,
what made it stuck?
Is some control light blinking? By this you will check if there is power in it.
All "reliable" trays should have little hole to poke with some wire. It's emergency button which doesn't require power to throw tray out.
Last option: Shame to damage such beautiful tray, try to pull it out with knife. From photos which I saw there must be a bit space to do it.
Cheers,
Mike
Leave rate if I helped you, thanks!
2answers
CD has physically stuck inside side loading (no tray) DVD drive on Laptop. Eject buttons both on media panel and via Function F10 are attempting to eject CD but it tries to move then refuses to eject. As...
The front of the CD Driver you can see a very small hole…use a safety pin and open it then insert the pin in that hole and push it in that will force the door on the CD to open …Let me know if that work for you and please do not forget to rate my service so I can keep providing this service to everyone and improve on it. God bless
5helpful
2answers
My mp4 player from carrefour gets hanged in the welcome screen after which i have to reset to switch it off and on restarting gets hanged again in the welcome screen
when it hangs press the reset button.. if u dont find it i can tell u how it looks like it loosks like a hole or a pinhole on the bottom ,top or sides if u find it poke it using a pin and it swiches off then try swiching on your mp4
Ford CD Mulichanger cassete stuck in multichanger
There should be a pin-hole on the front of the cassette, just like on a PC cd drive. Push a paperclip into the hole to release the cassette manually.
Eject button for cassette not working
look for a small pinhole to insert a pin to reset while powered up
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Marco Avila
Marco Avila
Marvin
Marvin
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
