Question about Apple iPad Tablets & eReaders
Using the keyboard for iPad not typing on the screen
The iPad is in a case with a keyboard how do I turn it on
Hampi Hemp
  • Apple Master
  • 706 Answers
Check the manual...!
depends on the model - but it works with bluetooth- see a sample :
put the iPad in the slot built into the keyboard, and pair it with your iPad via Bluetooth
On your iPad, tap the Settings icon and then tap Bluetooth. Make sure Bluetooth is On.
Connect the Logitech Ultrathin Keyboard Cover i5 Logitech Support Article Using the keyboard for iPad not typing on the scre - using-keyboard-ipad-not-typing-screen-jq4dbyibaqf10wv4m2e43laj-1-0.jpg
Posted on Dec 22, 2014
1 Related Answer
Arendicker
SOURCE: Keyboard Case For My New iPad?
I think you should go with zagg keyboard case . The case is the best seller and award winning also there are many other extra benefits of this product. To read real reviews on ipad cases click here to visit .
Posted on Jun 12, 2012
Slim folio will not be found with new Ipad 6th generation, we followed the instruction and nothing happens
You have missed a step. Read again carefully
Connect the Slim Folio keyboard case to iPad
Before you connect your iPad 5th Gen to the Slim Folio keyboard case, make sure it's inserted correctly into the case:
Place your iPad so the camera lines up with the camera lens cutout on the Slim Folio case.
Snap the corners of the iPad into the holder to secure it.
To connect for the first time
The Slim Folio case doesn't have an On/Off switch. To turn on your keyboard case, open it and rest the iPad on the strip directly above the keyboard. The status indicator on the top right of the keyboard will glow green.
On first connection, your keyboard enters Bluetooth discovery mode and the status indicator will blink blue rapidly.
Go to the Bluetooth settings on your iPad and select Slim Folio in the Devices list.
If your iPad requests a PIN, enter it using the keyboard (not on your iPad).
Once the connection is made, the status indicator will turn solid blue. Your keyboard is ready to use.
To connect to a different iPad
If you've already connected the Slim Folio case to an iPad and want to connect it to another one:
Rest the iPad on the strip directly above the keyboard. This activates the keyboard. You should see the status indicator glow green, and then blue.
Press the Bluetooth connection button on the right side of the keyboard to make your keyboard discoverable.
Close
Apr 17, 2018 | Tablets & eReaders
Tip
Restarting and Resetting iPad
Restart iPad: Press and hold the Sleep/Wake button until the red slider appears.
If you can't turn off iPad or if the problem continues, you may need to reset iPad. This should be done only if turning iPad off and on doesn't resolve the problem.
if the problems still not resolved Reset iPad settings. From the Home screen choose Settings > General > Reset > Reset All Settings. All your preferences are reset, but your data and media aren't deleted.
Reset all settings: Choose General > Reset, then tap Reset All Settings.
Reset network settings: Choose General > Reset, then tap Reset Network Settings.
Reset the keyboard dictionary: Choose General > Reset, then tap Reset Keyboard Dictionary.
Reset the Home screen layout: Choose General > Reset, then tap Reset Home Screen Layout.
Reset the location warnings: Choose General > Reset, then tap Reset Location Warnings.
on Sep 27, 2010 | Apple iPad (16 GB) WiFi Tablet PC
Keyboard covers typing space on Facebook
The button next to the .?123 in the right corner (see image attached) that looks like an icon of the keyboard itself is actually exactly for this issue. Press and hold this button and two options appear- undock and split. Undock will pull the keyboard halfway up the screen for this exact purpose, split will cut the keyboard in half like an ergonomic keyboard. For people who text frequently and find themselves typing with their ipad in their hands; this is a friendly option! Naturally thumb texters have split the qwerty keyboard mentally and will find this a very convenient option when needing to type with only their thumbs. Your ipad holds many tricks and bad a** features you may not realize even after years of ownership. I highly recommend "tips and tricks" guides in the App Store to find all the fun included features!!!
Jun 21, 2014 | Apple iPad Mini
Volume icon appears in the middle of my iPad 3 screen and won't stay off.
Do you have a case on the iPad? Sometimes an ill-fitting case can trigger the buttons by itself. If there is any lint or dirt between the case and the iPad, it can cause the same issue. If you have headphones with a volume controller on the cable - check that that is not being pressed by accident. You can also check to see if there is any lint caught inside the headphone hole. Sometimes that can cause a little electrical short and trigger funny behavior on the iPad. If none of those solve your problem, take it to the apple store, it could just be a faulty switch.
Apr 30, 2014 | Apple iPad 16 GB 3G Tablet PC
Cannot get ZAGG keyboard pair to iPad
Check that the keyboard's battery is working and it's on. Turn on Bluetooth on the iPad (Settings > Bluetooth). Press the keyboard Connect button. Choose the ZAGG Keyboard on the iPad, and type the code on the keyboard.
This doc describes the process: http://cfprod.zagg.com/downloads/ZAGGfolio%20instructions/ZAGGfolio%20instructions.pdf
Good luck! :)
Mar 25, 2014 | Apple iPad Tablets & eReaders
My targus versavu keyboard case for my Ipad 3 is charged but I can't type
Thank you!!! I held the home key and power button until the Apple logo appeared and now it connects to the key pad.
Mar 11, 2013 | Tablets & eReaders
May 30, 2012 | Apple iPad Tablets & eReaders
Tablets & eReaders Logo
427 people viewed this question
Top Apple Tablets & eReaders Experts
gaucherre
Shaukat Bhutto
Shaukat Bhutto
Nicola Conroy
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
