the calipers are in two sections
one section bolts onto the stub axle with 2 bolts and at the top of that section will be 2 bolts ( shafts) that are bolted to that mounting bracket
those bolts allow the caliper to slide so that the caliper can self center for equal pressure on each disc pad
there is normally a small rubber seal ( accordion shape) between the caliper body and the mounting bracket to keep dirt and water out but these fail and the slide section rusts onto the shafts
removing those bolts will be difficult as they will be rusted the full length of the slide but if you want the brakes to work properly it has to be done
yep,had one like that ,have to support the engine and trans with a bar and chains or whatever ,from the top and the subframe comes out from under.not too bad ,the steering rack bolts are the hardest thing,couple of motor mount bolts and the corner body to frame mounts
