TV ran good until power was interrupted recently. Now cable box has a green light but no signal to tv and continues requiring channel scan.
Main system control memory IC fault. This IC can be located at its main board; and is replaceable. Contact any service technician.
SOURCE: FLM3232 will not receive channels directly from Comcast Cable
Use the TV/Cable rf jack and auto program the TV.
Craig
SOURCE: Channel Scan on my Philips 26" TV only finds the local channels.
Hi.
you should go into your tv's setup menu and go to the tuner settings and make sure it is set to CATV (cable tv) and not Antenna/Air also splitting a cable to many times can cause the signal to weaken and gain a lot of noise/distortion that could be an issue that can only be solved by having the company come to the house and do a test ALSO when your in the tuner menu in under your tv's setup menu try adding a non local channel manualy and then see if the tv will tune to it, if so then you might have to add them manually at the worst... my guess is that it is not set to CATV/cable tv hope this helps and if not i hope someone else can.
SOURCE: no tv signal on my olevia 232-s12
cable or Ant.. ? after the scan if there is no channels found (0 digital, 0 analog) then try with cable or Ant to see if any of them work.. if they still don't pick up any channels and the whole yellow progress line goes across.. then it sounds like the tuner on the tv is bad.. and the tuner is part of the main-board so the whole main-board will have to be exchange or repair.. contact Amergence technology they are a 3rd party repair center that service Olevia TV's and they will be able to give you an idea on the repair cost..
<<< Amergence Technology number is 866-965-3842 >>
SOURCE: TV Cable card slot loses signal immediately after channel find
THis is not a solution but a similiar issue. I have had a scientific Atlantia Cable card with comcast for 3 years no problems at all. Spent the entire day trying to switch to Verizon today. The signal comes across for about 10 seconds, pixelates and then fails. This happen after every start. We have checked the lines, tried 2 cards and reduce the signal. We gave up for today- installed the old Scientic Atlantic, reassigned it to comcast and all works fine Any and ALL suggestions are most welcome Thanks
SOURCE: Will Not Find A Signal Polaroid HD 15" TV - Model TLA-01511C
TRY TO WATCH TV ON POLAROID 19"TV TLA-01911C /can I watch tv without a converter or how do I set up my tv/dvd/converter
