Note - after researching the internet I picked what I think could be the model number.
Manual. Looks like the same machine is sold under different brand names. See if you can find yours here.
KitchenAid KAWS750L
kitchenaid washer stops YouTube
SOURCE: Kitchenaid KAWS750JQ3 Top Load Washer
hi there,
make sure that the program is not on the "Intermittent Agitate Program". that would be the cause of the delay.
the other issue would be the timer itself. the timer is mechanical, so once the contact on it is corroded, it will only function intermitently or not at all.
please let me know if i can be of more help.
thanks
SOURCE: I have a Kitchenaid super capacity 14 cycle Quiet
you may have 2 problems, first check the lid switch for a broken or burnt wire, part #3949237 if needed. also, take a look at the direct drive coupler on the shaft of the motor, it is made up of 3 pieces and it may have become damaged. hope this helps.
Testimonial: "" Thanks very much for your quick responce and solutions. They are very helpful. Thanks Ari Gelfant " "
