Samsung 2.0 cu ft Over-the-Range Microwave Stainless Steel SMH9207ST Logo
J
James Hoffman Posted on Sep 15, 2014
I bought a Samsung SMH9207ST over the range mircowave/hood open box. I do not have the templates for the wall or the above cabinet. Where can I get them?
I already have the electric outlet ready, the bracket for the wall and the hardware package. I only need the templates.
Over range microwave doesn't fit in the space outlined by the installation template
You missed something while reading the installation directions but that won't fix it. since you already drilled holes in the wall lower the mount down as needed then drill new holes in the mount to match the holes you drilled in the wall. The problem would have been worse if you were off left or right... up and down is easier. Remember you maybe just not dropping the microwave low enough to fit in the slot at the bottom of the wall mount before you tilt the micro up.. check it one more time...including the directions before you re-drill
Over The rang microwave installation
I would say finish the wall, because the microwave needs the space for cooling.
1helpful
How to uninstall a Whirlpool microwave Hood Combination? Model MH6600XV
Unplug the range and move it out of the way.
Open the cabinet above the microwave.
Unplug the power cord.
Remove the 2 bolts going through the cabinet into the top of the microwave.
Have a helper hold the microwave in place before these bolts are removed.
After the bolts are out,assist the helper by lowering the front of the MW and lift the back of it off the mounting bracket attached to the wall.
They are heavy and awkward.
A helper must be used.
Instalation Instructions for Frigidaire Over the Range Microwave 850 Watt Model #FMT118EPB
HI,
Frigidaire makes several over-the-range microwave models that are all installed in the same manner. To install correctly, you must have at least 45 1/2 inches from the bottom of the top cabinet to the cooking surface of the stove to provide enough clearance for the microwave. The top cabinet must also be at least 30 inches wide and 12 inches deep. Find someone to help you, then follow the steps below to install your Frigidaire microwave.
Things You'll Need:
  • Stud finder or hammer
  • Screwdriver
  • Drill
Instructions
Pull your range away from the wall so you can work comfortably. If this is not possible, cover it with a drop cloth. Find and mark the locations of the studs in the wall behind the range. They will be either 16 or 24 inches apart.
Follow the instructions on the wall template to mark the location of the mounting bracket and the four anchor holes on the wall and the bottom of the cabinet. Drill the anchor holes. Follow the instructions on the top cabinet template to mark and drill the two holes in the bottom of the cabinet.
Attach the mounting bracket to the wall studs using the six wood screws included with your microwave. Screw the toggle nuts onto the toggle bolts and push one through each of the four drilled holes. Screw each toggle bolt until the nut is snug against the inside of the wall.
Pick up the oven with your helper. Plug the oven into the outlet and slide the oven onto the mounting bracket arms. Push the oven back against the wall. Tighten the two screws on the microwave faceplate to fasten the microwave to the mounting bracket arms.
Attach the louver to the top of the microwave with the three provided screws. Insert the two top cabinet screws and washers from the top cabinet into the microwave and fasten tightly.
Take care.
3helpful
I am seeking a template for re-installing my 2 year old microwave. Jenn-aire has none of the templates in stock and can't send me a pdf or file so I can print the template myself. I have tried 2 parts...
Since you can't get a paper template for remounting your microwave, I can offer you my tips for doing this, as I've had to reinstall many of my customers microwaves, after they've done a kitchen remodel.
You can use the metal mounting bracket as your "new" template. Just unmount the micro and remove the metal bracket and you can then position it on the wall or under the cabinet where you are looking to mount the microwave. However, before you remove it from the wall, simply measure the distance from the edges at the top and both sides of the bracket, where it is presently mounted and you'll be able to easily remount it in a new location.
If you've already removed it from the wall, not to worry, simply place it on the back of the microwave and measure the distance from the edges of the bracket to the top and both sides of the microwave's canbinet edges. Allow for 3/16" additional distance and you should be able to then remount the bracket at the new location with ease.
Please remember that you want to get the bracket secured into a wall stud so it can hold the weight of the microwave once it's installed and fastened to the bracket. I also recommend that you use wall anchors at the side edges at both the top and bottom corners to help secure the bracket IF there are no wall studs behind the predrilled holes for mounting the bracket to the wall.
If you have trouble using the metal mounting bracket, you can always trace the entire bracket onto a piece of heavy paper or cardboard, but frankly, I find this unecessary and time consuming, since you've already got the mounting bracket right there with all the holes and such.
Also, don't forget to measure the location of the power cord at the top or back of the microwave and remember you'll need to drill a hole in order to be able to pass the cord thru the cabinet. If your microwave has screws at the top front edge that help secure it to the cabinent above it, again, simply measure the distance of these mounting locations from the sides and back of the microwave cabinet and drill holes thru the cabinet, using a drill bit that is twice the diameter of the mounting bolts. You should add washers to these bolts to help prevent the bolts from pulling thru the cabinet bottom.
Mounting a microwave is best done with at least two people, as holding it in place while someone else puts the bolts in it isn't easy to do by yourself. Also, it is much easier to do, when installing it over an existing range, if you move the range out of the way first, so you can stand under the microwave, instead of having to lean over the range while trying to install it. Not to mention the fact that should you drop the microwave, you'll not only damage it, but could destroy your range at the same time.
Hope you find this Very Helpful and best regards!
2helpful
I bought a used over the range microwave oven( kenmore) I would like to know how to install it knowing there is an opening to the roof. thank you
Most Kenmore microhoods use a 3" by 10" exhaust duct. Check for correct demensions. Make sure that the existing vent is this size or that you have room to adapt to this size. There should be a damper mounted to the top of the micro which will attach to the vent duct work. You will need an outlet in the cabinet above the micohood. This should be on a circuit of it's own. The microhood should have a wall plate for the back wall. I'm going to assume there are no templates available. Hold the wall plate against the back of the micro to determine the height placement in the opening. Most install centered under and against the cabinet above. Not all do, so this will confirm. Mount the wall plate to the existing wall studs with at least 1/4" by 2-1/2" lag bolts. Bore an 1-1/4" hole in the right rear corner of the cabinet above, about 2" out from the back of the cabinet and 2" in from the side, this is not a critical measurement, it is to pass the electric cord into the upper cabinet. There are two screws that support the front of the hood. I believe they are 1/4" by 3-1/2" long. If not included, check for size. The hardwae will have them, get flat washers to fit both also. Measure from the back of the micro to the mounting holes in the top of the micro, include the wall plate in this measurement, they'll be about 10" out from the back and about 1-1/2" in from the edge, near the front, but check that measurement, they vary. Drill 3/8" holes in the bottom of the cabinet at these locations. If doing this alone, best that you move the range out. It's nice to have a helper at lifting time. With the plate on the wall and the holes in the bottom of the cabinet, your ready. Put the 1/4" screws and someting to drive them in the upper cabinet, so they'll be available. Lift the micro into the opening with the front tilted downward, hook the back of it into the bottom of the wall plate, push the cord into the upper cabinet, tilt the front of the micro up until you can start the front support screws. Start both, don't let go of the micro until you are sure that both screws are started and will support the front weight. Once you're sure, tighten both screws all the way and connect the vent. Steel tape is best for sealing up any leaks. Power up the outlet, plug in the microhood and put in the popcorn. Get a good movie and enjoy in your accomplishment. Congrats. PS: Make sure the roof vent opens when the hood is turned on, I have seen them stuck shut from grease build-up.
6helpful
Microwave range hood install -- stud in middle of exhaust
You have a few options, First off, I am assuming that the stud you refer to is an outside wall. Assuming that is true, then you have a few options.... one of them is to cut thru the stud and run the vent out. Even if that stud is on a bearing wall ( meaning it is carrying a roof load above it) ... It is unlikely to pose a problem if that one stud has been compromised with it cut out, If that concerns you.. and you are handy, you can open that area of wall up from the inside and box the area that the vent will be located in with short pieces of 2x4 to the studs on either side of it... Another option is to vent the hood up thru the cabinet above and direct that out slightly offset to the stud in the wall..
One thing I have done is to cut the stud out and then to place a piece of 1/2" plywood in the area that the micro/hood will be located and attach that piece with drywall screws to the studs in the wall.. That piece of plywood will help support the stud you cut when you screw it to the adjacent studs and also act as a place to secure the hood mounting bracket on the wall. Granted, it shifts the hood out from the wall 1/2 " but then you have plenty of surface to secure the plate and don't have to worry about hitting a stud or using wall anchors.. I hope you understand my comments..If not...please respond to this and I will provide additional information to clarify this... Hope this helps !
1helpful
Microwave installation under cabinet, no rear wall
Hi , I would like to suggest to visit near appliance center to purchase hanging for oven . ace hardwares.
Top Samsung Microwave Ovens Experts
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
