Question about Biddeford Blankets Heated Mattress Pad with Digital Controller"
Why has my heated mattress pad stopped working?
I have the queen model with dual controls. The controls light and go through the settings as usual with no errors but neither side of the pad gets warm. I checked the connectors and they are clean and snug. Also, the pad is laid out flat and smooth with no apparent kinks.
Posted by Jafu Bumbalini on
pcfixup.ca
    Sergeant:
  • 269 Answers
Electronics fail. Sounds like the digital controller has failed. A Google search finds others with the same problem. Biddeford models come with a 5-year warranty, so if yours is less than 5 years old, I suggest you contact Biddeford by telephone: 800.789.6441 or visit their website: http://www.biddefordblankets.com/warranty.asp
Posted on Sep 15, 2014
I am looking for a replacement for 1 of the controls for my heated mattress pad. Where can I find 1?
www.sunbeam.com/.../bedding/controls/bedding-contr...
Sunbeam ProductsHow do dual controls work? The dual ... What if my control does not regulate my side of the warming product? ... Where can I purchase replacement controls?
Finding Replacement Cords and Controls for an Electric ...
www.thriftyfun.com/Finding-Replacement-Cords-and-Controls-for-an-El...
... blanket. Finding a replacement cord or a control for an electric blanket can be difficult. ... My blanket was under warranty and I got one for free. If yours is out of ...
Finding Replacement Controls for a Heated Mattress Pad ...
www.thriftyfun.com/Finding-Replacement-Controls-for-a-Heated-Mattre...
This is a guide about finding replacement controls for a heated mattress pad. It can be very frustrating to find replacement ... Read all 1 Answer ... Where can I findreplacement controllers for my Living Quarters heated mattress pad? By Steve.
Replacement Controls for a Sealy Electric Blanket ' ThriftyFun
Dec 07, 2015 | Sealy Heated Queen Size Mattress Pad - -
How do i fit brake pads to my speed queen toploader
American model?? renew the brake light switch .they are different to europeon models .We have seperate lights so brake light isnt the indicator light as well .Fancy switch cost a few sheckels
Oct 09, 2012 | Cars & Trucks
We have an F1 error code, and cant get the oven to stay on...it sets for a minute, then beeps a few times, and shows a f1 code again
F1 touch pad / ERC test
This simple test will help determine whether the ERC (Electronic Range
Control or Clock) or the touch pad is defective when F1 error code is
present.
Note: Some models incorporate the touch pad in to the ERC
as a single assembly, in which case this test is not necessary. Simply replace
the ERC (Clock).
Warning: If you feel in any way uncomfortable
performing this test or making this repair, please contact a qualified appliance
repair technician.
1. Disconnect power to the range (unplug the range
power cord or turn the power off to the range at the circuit breaker). It is
very important that the power to the range has been disconnected, so please
double check before continuing.
2. Gain access inside the control
panel.
3. Disconnect the touch pad (also called keypad or membrane switch)
ribbon from the ERC.
4. Make sure there are no lose wires, or anything else
that may cause a short when power is turned back on. Assemble the control panel
back the way it was.
5. Turn the power back on.
6. Wait for at least one
hour to see if the F1 code comes back (usually accompanied by a beeping
sound).
7. If F1 comes back, replace the ERC. If it does not, replace the
touch pad.
Dec 05, 2010 | Kenmore 79383 Dual Fuel (Electric and Gas)...
I'm getting a periodic beeping signal and an "FO" error message from my lower oven. What is it telling me? The oven is a dual electric. Model number 326B1230P001. Thanks. Stanley Hochman
Hi!! Failure Code Fault Code Description Solution F0 Stuck touch pad Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
Although the manual recommends to replace the touch pad, try unplugging the unit form the wall for a couple of minutes to reset it. It works most of the time.
Good Luck!! Don't forget to rate this post!!
Sep 20, 2010 | GE Profile JGSP44 Dual Fuel (Electric and...
I have a Sunbeam Queen washable electric Blanket dual control model BL445D. One of the detachable controls is not working and I would like to buy a replacement one? can you tell me where I can find one...
Hi. You can locate a Sunbeam Service Centre via http://www.sunbeam.com.au/Pages/Support/Repairers.aspx
You're looking at $64.00 recommended retail.
BTW have you checked that it's not the blanket? Swap the controls over, if the problem follows the control it's the control. If the problem stays on the same side of the blanket, it's the blanket.
Also note Sunbeam has a 3 year warranty on electric blankets. If Date Of Purchase is less than 3 years ago call 1800025059 option 1 to speak to their Customer Service,
May 26, 2010 | Sunbeam Heating & Cooling
Character moves side ways without me touching it. it also fights me for control while i'm playing
go to control panel and open "game pads" or "game controllers"
then choose properties for your game pad and choose the calibration tab, calibrate and set click ok and check if problem has been resolved
Jan 05, 2010 | Sony PS2 Dual Shock 2 Controller...
I have a neff T1.D20 dual circuit hotplate but although the inner lights up and gets hot the outer part doesnt. Is the outer part supposed to?
I have a T172 model which also has a dual circuit hotplate.
In the control area you should find a dual circuit control pad - this has two concentric circles on it. With the hob switched on, pressing this button will chnage the mode of the dual circuit hot plate bewteen:
1. Just the inner part
2. Both the inner and outer together.
When the hob is switched off using the Standby control pad, it remembers which mode was selected and will therefore work the same next time it is switched on. However, it is worth noteing that when the mains power to the hob is interuppted, either by an isolator switch/breaker, or a power cut, the hob defaults back to just the inner ring mode.
Oct 03, 2009 | Neff T1323 Electric Cooktop
Biddeford Blankets Heated Mattress Pad with Digital Controller" Logo
2,358 people viewed this question
Top Biddeford Blankets Furniture Experts
Tom Chichester
Andrew Taylor
Andrew Taylor
Are you a Biddeford Blankets Furniture Expert? Answer questions, earn points and help others
