Sony Cyber-Shot DSC-S40 Digital Camera Logo
Question about Sony Cyber-Shot DSC-S40 Digital Camera
Cybershot flash no lights
I have a sony cyber shot camera model DSC-S40 THAT ITS FLASH have worked already,but it DOS NOT WORK YET.What is the problem and what can I do?
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: flash does not work
try going to the user manuel to see of to turn your red eye reduction on and off turn of then reset your flash it should work then
Posted on Dec 16, 2007
Anonymous
  • 871 Answers
SOURCE: sony cyber-shot dsc-w55 flash doesnt work
hi
the flash doesnt flash anymore, you may need to replace th bulb for that. the yellow light means its a warning that the bulb is wor out.
hope this helps
Posted on Jan 22, 2008
Anonymous
SOURCE: problem with sony dsc-w30 cyber shot flash
I found this solution in Yahoo Answers. go into the Setup Menu and find "Initialize". Select Initialize to reset the camera adjustments. Then try using the camera again.
Posted on Feb 17, 2008
Anonymous
  • 107 Answers
SOURCE: Memory Stick error c:13:01
Is your new 2GB memory stick is original from Sony or after market? some of them will not detect in CAM because the contact on MS were not touched iside the slot of CAM
Reinsert your 512 MB MS if it work fine then change your 2MB MS
Good luck
Posted on Nov 30, 2008
ripleymojica
Mando Mojica
  • 643 Answers
SOURCE: My Sony Cyber-shot DSC-W200 flash has stopped working and when I try to reset it it tells me that flash cannot be reset. What can I do?
its circuit error need to replace flach unit
Posted on Jun 01, 2009
2helpful
Sony Cybershot DSC-W55 flash not working Code
GO TO SETUP MENU, SELECT THE TOOLBOX ICON 1 AND SELECT INITIALIZE CLICK OK.
Sony digital camera DSC40, flash busted, not working
how to activate or replace flash on my sony cybershot model# DSC-H5
2answers
Flash of sony cybershot dsc-w200 is not working
i think i had the same problem, if u press the home button and then press shooting then hit the flash button on the right hand side it should change the mode.
Sony cybershot dsc - w55
the part which comes out when the power is on might have got stuck .. there may be some dust particles. just blow over it or vaccum it..
8helpful
2answers
White Display on Screen
I fixed the camera myself as follows:
1. Hold camera firmly in left hand
2. Smartly rap front of camera with knuckles of right hand on the "Cyber-shot" logo.
It worked, now the LCD is working again for free.
Guess I don't need to pay Sony $111.00 for repair service.
Best Regards .
M.R.Mohajeri - I.R.Iran
2helpful
Sony cybershot dsc-s650 camera
Just take the back cover off, unplug the cable that runs to the switches from the main board and plug it back in. I had the same problem and it now works great!
2answers
Sony digicam DSC W1
If you cannot find a solution to your problem you may want to email [email protected]. He has good advice and good used parts at a fair price.
Flash does not work
Top Sony Cameras Experts
W.L.
matt
matt
Darran Hatten
Are you a Sony Camera Expert? Answer questions, earn points and help others
