Sofa, with 2 end tables and coffee table, patio set, lawn chairs, 2 china closets
SOURCE: stain on marble/stone table
use a simple paint remover
what kind of paint was used on the pumpkin?
SOURCE: need leveling screws (bolts) for my patio table legs
Hi I would try a local patio supply place. Something like BBQ galore
SOURCE: I need help writing a complaint letter to art van
I would also contact the Better business bureau in your area. I have had a lot of luck going through them.
SOURCE: Restaurant Pro Express - Will not let me do "End
You didn't give your version #. Different versions have different options. Keeping that in mind, try going to OPTIONS, CASHIER FUNCTIONS, RECALL ONHOLD INVOICES. If you have any thing listed here, you can't do END-OF-DAY. Void this or recall and delete items on it.
If this doesn't help, you will need someone to delete the invoice manually from the database. Very technical issue. I would be available if you don't have tech support contract with PCAmerica. Contact me at [email protected]
Yes. These chairs are made from aluminum and are therefore permitted to be used outdoors.
The size of your coffee table depends on the size of
your living room and the setup of your living room furniture.
You can find the right coffee table by measuring exactly how much space you
have in your living room and what's your table's main purpose.
The textbook coffee table shape is rectangular
although furniture designers create endless variations on this shape, in which
the table surface is just one component. You should consider how you'll be
using it. If you frequently entertain guests, you may want to consider a
circular or oval coffee table. Round furniture pieces tend to be better at
gathering groups of people, and they are easier to maneuver around safely.
Sofa tables are like wide end tables that a generally placed in foyers or behind a sofa that is positioned in the center of a room.
A coffee table is a table that is long and low. It is meant to be at the same level as your couch and is generally used for drinks and finger food.
