Question about Westinghouse LTV-32w1 32 in. HD-Ready LCD Television
Tv turns on but no picture
Westinghouse 32 in tv model # ltv32w1 turns on but no picture
    Top Expert:
  • Westinghouse Master
  • 76,396 Answers
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Posted on Sep 15, 2014
5 Related Answers
dave1645
Dave Naylor
  • 834 Answers
SOURCE: Westinghouse TV no picture just sound. 32
one or 2 caps in the power supply they will be domed from venting
Posted on Sep 16, 2009
Anonymous
  • 7 Answers
SOURCE: westinghouse ltv32w1 has power light but no
Believe it or not...I repaired my Westinghouse LTV-32w6 HD TV. it had no picture and just sound. I took the back part off, I took the stand off, and then I took the metal plates surrounding the main board and back light inverter off. I inspected the backlight inverter, saw nothing bad, inspected the main board, saw nothing bad, inspected the power supply, and saw nothing bad. What I did notice was the flimsy aluminum foil tape that I guess is supposed to ground the metal chassis around the TV. I did not see any other means of grounding except this. In my opinion, this was poor grounding. I went ahead and took the main board off; at this point there are a lot of connectors you have to disconnect. The good thing about these connectors is that they are all unique so you really can’t connect them back the wrong way. So, I found another smaller metal plate on the back of the LCD. I took off the plate and I found that there was a board with the numbers “V320B1-C” on it. This board had four connectors at the top and 1 at the bottom. (yours might be different) I noticed that there was a burnt spot on the lower right side of the board. By the way, this board is called the LCD controller board. I thought to myself, if I replace this board, it can be fixed. I went on EBAY and found used boards for under $50. I even found out that these boards are also used buy 32” Poloroid LCD TV’s. Anyways I ordered the board, installed it, and BAM! The board exploded! It blew up at the same place the other board had the bunrt spot. Damn I lost about $45. OK, I was not about to quit yet. I should have done more inspections. I inspected the 4 connectors at the top of the board. It has 4 short flat cable strips. I noticed that two of them had very small burnt spots on them. So I took the LCD itself apart (many more screws to take off) and inspected the thin side boards and didn’t find anything bad. So I put the LCD back together and went ahead and ordered the same board on EBAY. This time, before you order the “V320B1-C” board, MAKE SURE YOU ASK THE SELLER IF THE 4 UPPER FLAT CABLE STRIPS COME WITH IT, IF NOT ASK HIM TO INCLUDED IT. It might cost a bit more but it would be worth it. If the seller doesn’t have the strips, then don’t get the board; keep looking. ALSO, COMPARE THE EBAY PICTURE OF THE BOARD WITH YOUR BOARD AND MAKE SURE THEY LOOK IDENTICAL. Some boards will have the same model but will look different. After you get the board and the flat cable strips, do a quick inspection on the board and cables to see if you notice any burnt spots. Install the cable strips and board, then put the metal plate on top of it. Connect all the wires back together to the main board, speakers etc. Put everything back together, EXCEPT the back part. Last thing, you will need wire strippers, and a piece of wire (about 2 foot, 18 awg stranded and insulated, like thin speaker wire). Remember the aluminum foil tape that supposedly acts like a ground, you will make a better ground. Look at the bottom left edge, the screw that holds down the metal chassis (any screw that touches metal), loosen the screw, get the piece of wire and strip the end to expose the wire. Wrap the wire around the screw and tighten the screw. Now run the cable up and around the edge of the LCD, skip two screws, loosen another screw that holds metal chassis, and cut the cable and strip to expose the wire and wrap the wire around the screw, but before you tighten, get a second piece of cable, strip it and wrap around the same screw, and tighten. Repeat this process until you reach the bottom center part of the LCD. Connect the power and cable to it and cross your fingers. I was so happy when I saw the WESTINGHOUSE logo come up on the screen
Posted on Nov 08, 2009
dave1645
Dave Naylor
  • 834 Answers
SOURCE: my 32 inch westinghouse lcd tv's screen turned pink when on
your T-con board is failing you need a tech to replace it about a 150 dollar job
Posted on Nov 18, 2009
SOURCE: My Westinghouse TV LCD has no sound but has
there are so many reasons why your TV won't bring out sound. You need to troubleshoot first, in order to get to the root of the problem, before a solution can be proffered.
First, connect a DVD player to the TV, observe if there is going to be sound. If there is still no sound after connecting the DVD player to the TV, proceed to the next step. "The reason why I asked you to connect a DVD player to the TV is to confirm if the problem is simply not from the audio cord connected to the TV."
Second, get an headset, connect it to the earphone jack of the TV and observe if there is going to be sound. If there is no sound, then it is glaring now that your TV is having a defective sound card/IC that's why it is not bring out any sound. (Note that connecting an headset to your TV is optional because not all TV's has a space for headset). "The reason why I asked you to connect an headset to the TV is to also confirm if problem is not from the TV speaker. Though TV speaker problems are rare but sometimes, the TV speaker might be defective or the speaker wires may have loosed contact or cut into two, due to one reason or the other. But if the headset doesn't bring out any sound from the TV, then it is not so."
If none of the above seems not to be the cause of the problem, then the above troubleshooting has confirmed that the TV has got a defective sound card/ic. The sound IC/card of the TV has to be replaced for the TV to bring out sound again.
To be honest with you, replacing or fixing the sound card/ic of your TV requires the ability or experience to do so.
Now, if you are convinced you can fix or replace this yourself, please reply so that i can help you further. And make sure you troubleshoot first, before getting back to me.
Regards.
Posted on Nov 09, 2011
ray lucas
SOURCE: I have a westinghouse tv model number SK-32H240S no picture
its a inverter transformer, part no. sk32h2405 b070401
replace this and the picture will come back on
Posted on Apr 16, 2013
I have a Westinghouse lcd tv i have a thin green line on left of screen from top to bottom model #ltv32w1
T con board or the LCD panel is faulty.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apr 26, 2016 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
I have a white westinghouse 40 inch tv model vr4090 and the tv wont come on it shows the power indicator turn from red to blue but no picture or sound
Westinghouse tx-42f430s wont turn on fix repair - YouTube
? 5:29
https://www.youtube.com/watch?v=DdfLu5RdVEQ
May 12, 2014 - Uploaded by After Hours Tv & Pc repair
Westinghouse model # 32H1G1 won't turn on , but If I unplug the TV and wait for a ... -tx-42f430s-42-inch-lcd-tv-appears-bricked-595806.html ... I have a Westinghouse 40" TV that is working, but sometimes it won't turn on.
Westinghouse LED LCD TV Repair - YouTube
? 12:32
https://www.youtube.com/watch?v=DGg5iuFEfdM
Feb 8, 2014 - Uploaded by INSIDEHARDWARE CHRIS
Westinghouse Model: LD-4680 Similar (LD4655VX LD4255VX ...Samsung LCD TV Repair - TV Won't Turn On - How to Replace Power Supply ...
40 inch Westinghouse lcd tv black screen help - YouTube
? 1:39
https://www.youtube.com/watch?v=tKLRihGgZAs
Nov 21, 2011 - Uploaded by Jason Flynn
Dec 19, 2015 | Westinghouse Televison & Video
THE tV GOES BLANK WITH NO SOUND 5-10 MINUTES AFTER TURN ON. The blue pilot light in front stays on and sometimes goes yellow . The Tv will sometimes work again if I turn it off and them back on.. Model...
Power supply board is going.Not giving the right voltage to the tv anymore.That why,power it is not consistance.The power supply board,that the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sep 26, 2010 | Westinghouse LTV-27w7 7 in. LCD HDTV
I have a Westinghouse LTV-32w1 Televeision. My screen is cracked and I would like to replace it, as the TV works great. Where can I buy the screen?
You will pay more for the replacement panel then you will for repalcing the TV. The part number is LTV32W1-LCDP and is no longer avilable.
Sep 10, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Manual for LTV32W1 WESTINGHOUSE TV
You can download the required manual from:
http://www.westinghousedigital.com/pdf/15_User_Manual.pdf
Hope this solves your problem. For more help and clarifications, please reply to this post. Thanks
Aug 25, 2009 | Westinghouse Televison & Video
How do I change the channel on my Westinhouse LTV32w1?
I found my owner's manual and it provided me with the directions to change the channel to 3 (the setting to receive the signal). Problem solved.
Jun 26, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
I have a 32" TV/DVD combo westinghouse LCD TV. When I turn the TV on I get no picture. There is sound. DVD player does not show picture either, I have sound but no picture.
This is a backlight or inverter Problem. Based on the model you have, I am guessing the inverter is defective.
Inverter is defined as the board in the TV that supplies power for the flourescent lights inside the LCD TV that provide backlighting for the TV's Display
Jun 22, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Don't have remote for westhouse ltv32w1, can't setup tv
Partstore.com has it for $19.95. It's under remotes, then TV remotes, then Westinghouse digital, then under LTV-32W1.
Feb 01, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Westinghouse 32 inch screen goes blank
replace capacitor c162 on power supply
power supply was a delta electric dps210ep-2c rev01
reheat any solder joints that don't look 100% as well .
such as c310 .
this is a known working fix . try before you buy a supply .
Dec 25, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
32inch westinghouse LCD TV flickers/slighly shaky picture-LTV32W1
try reseating the LVDS cable inside the set it is the multi wire connector from the main board to the LCD panel (top portion of the panel). if that doesn't look to see if the back lamps are remaining lit during this problem. if they go out the problem may be power supply or inverters (lamp power supply).. some panel makers make these available as a seperate part, some do not and the panel must be replaced. if the back lamps stay lit it is the main board. start with the LVDS cable first.
Apr 24, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
197 people viewed this question
Top Westinghouse Televison & Video Experts
CoppellTVRepair.com
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
