I lost the instructions for setting this timer and cannot figure out how to set it.
Http://waterheatertimer.org/Westinghouse-timers-and-manuals.html
Link above has possible manual
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: Need to re-set time on Salter digital timer
If it's the same as ours (clock button top left, clear bottom left):
Hope it works
SOURCE: Lost the instructions need help setting it up for
Here ya go:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/dt300.ashx
Testimonial: "great instructions, thanks"
SOURCE: ge digital timer how do i set
http://www.jascoproducts.com
select support and enter the model number (15079) in the search field. the manual is downloadable. One thing the manual does not make clear is that the two plugs in this timer cannot be set independently of each other. Whatever two devices you plug in will go on and off at the same programmed setting.
SOURCE: I HAVE MODEL #83643B POWER STAKE AND 15 FT DIGITAL
That sounds like the Woods 17321 Dusk-to-Dawn yard stake
Product image:
http://www.amazon.com/Woods-17321-Outdoor-3-Outlets-6-Foot/dp/B000BHN4H8
Manual
http://waterheatertimer.org/pdf/Woods-17321.pdf
If this is not your timer, check following page:
http://waterheatertimer.org/Woods-timers-and-manuals.html
Instructions:
Yard stake control outlets, and turns ON automatically at Dusk
Rotate dial to set options:
Rotate to OFF > outlets OFF
Rotate to ON > outlets ON
Rotate to Dusk-dawn > outlets on at dusk and off at dawn
Rotate to 2 4 6 8 > outlets on at dusk and off 2 4 6 8 hours later
