How do I replace the gasket on my front loader lg washer due to mold and mildew.
SOURCE: rubber gasket removal LG Tromm front loader
We found there is three small holes on the seal right inside the door, check to see if they are clogged with soap scum and clean them out. Run a cycle of hot water and bleach. Then, after each use, leave the door open and let it air dry and this has seem to work.
SOURCE: mold and mildew in door deal of LG front loader WM
Barb,
This is a problem with all front loaders. We have used those cleaning tablets in a regular hot cycle per the directions on the box. You can also try placing 1 cup of crystal dishwashing detergent in the tub and fill the soap dispenser with bleach and run a quick cycle full hot.
SOURCE: I have mold and dirt under the LG front load
Tilex Mildew Remover and an old toothbrush work wonders on this. Magic Eraser works like a charm on tougher jobs.
Hope this info was helpful to you. Good Luck!
SOURCE: My front loader gasket is permanently stained with
Washing machine door gaskets are available for any make of washer.
Contact the manufactures direct, or look on the internet.
Try E-Bay as well, you should not have any trouble obtaining one.
