Question about FUJIFILM Cameras
My fujifilm xp60 will not turn on, the battery is okay. the battery is inserted properly.What other cause could there be ?
Battery is okay and inserted correctly. Push the on off button and nothing happens
tomalex
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 39 Answers
Make sure battery is actually charged and charger is not faulty. Try a different battery? Make sure contacts on battery and camera are clean. If the camera still will not start, it may need to be serviced.
Posted on Oct 07, 2014
5 Related Answers
Anonymous
  • 150 Answers
SOURCE: wont turn on
Only use Ni-MH or AA-size alkaline batteries. Do not use Ni-Cd (nickel-cadmium) because the heat emitted can damage the camera.
I would suggest using e2 batteries from Energizer.
In the manual, on page 80 there is a description and procedure for discharging Ni-MH batteries (but NOT regular batteries, so don't do this with regular alkaline batteries) AND do not do this when the external power is connected.
Moving on... The discharging of the batteries procedure should happen when:
  • the batteries last for a short time after being charged normally
  • the batteries have not been used for a long period
  • the batteries are new.
Follow these instructions:
  1. Press the menu/OK button to display the menu on the LCD monitor
  2. Press the "left" or "right" on the pad to select "SET" OPTION and then press "up" or "down" to select "SET-UP".
  3. Press the "MENU/OK" button to dipslay the "SET-UP" screen.
  4. Press "right" or "left" to move to option 5 and then press "up" or "down" to select "DISCHARGE".
  5. Press "right"
  6. Press "left" or "right" to select "OK".
  7. Press the "MENU/OK" button.
The screen changes and discharging begins. When the battery level indicator blinks red and discharging ends, the camera turns off.
Remember to not have the camera external battery plugged in so the battery can discharge on it's own.
Then, at this point, recharge the battery using the external battery charger. This helps to "renew" the battery. This is because Ni-MH batteries will remember the last place where they recharged, and too many times, the memory "bookmark" gets marked to low and has to be reset, done by the recharge.
It may be necessary to repeat these steps multiple times. This effect is not because the batteries are deffective. This is a normal side-effect of Ni-MH. This is the reason the camera comes with a discharge feature.
I the batteries are old and don't function even after performing the discharge procedure as part of the normal operation of the camera (like of the year or two), then the batteries may have reached the end of their service life.
Hope this helps, if so, please rate FixYa! ThankYa!
Posted on Dec 04, 2007
Anonymous
SOURCE: fUJIFILM FinePix A360
my A360 digital wont turn on it flashes green then goes off i put new batteries in it
Posted on Sep 30, 2008
Steve5
Steve Grezoux
  • 423 Answers
SOURCE: Card error with compatible memory card (Z30fd - Fujifilm)
Try doing a "format" of the card through the set-up menu.
Posted on Aug 08, 2009
david
  • 244 Answers
SOURCE: fujifilm finepix v10 does not turn on. when
Fuse F351 has possibly blown on the board. It is a 2.5A 32v UL type surfacemount fuse which is soldered to the board. The fuse has a coded letter on it for identification. Recomend you find someone who knows electronics to repair
Posted on Jan 03, 2010
micromaster
micromaster
  • 3614 Answers
SOURCE: When I push the off/on button, nothing happens.
For clarification, how many years that you have the camera. Did you already changed for a new battery? Is there any incidents that you dropped the unit?
First make sure that you properly inserted the battery, check the electronic contact for any dirt/rust on the battery and to the tray.
Battery life can be the issue here, if you have not yet change the battery try to change or use new battery. In some cases like this battery cannot hold anymore power when you try to charge it.
It defends how frequent you use the camera, as long as you use it it will also shortened the battery life.
Let me know here again for further more assistance.
Thank you for using fixya.
Posted on Jun 23, 2010
New unlocked cell phone won't turn on
Hey, same problem. Push and hold the hangup button. It will prompt to insert sim , but I only have one. The phone works. The website and the manual are useless. Just gotta play with it, I guess.
Mar 06, 2013 | Cell Phones
97 Suzuki LS 650 Savage won't turn over. Battery is charged to 12 volts, and I replaced the fuses, but still nothing. When I push the starter button nothing happens. No clicks, no lights dimming.
if you can arc and get it to work
what are the battery terminals like... clean and tight
check continuity for the earth chassis to battery neg - terminal wire
also the wire voltage to the starter from pos battery
if that checks out
bench test starter
solenoid not kicking out properly or problem with lazy starter motor
Apr 12, 2017 | Suzuki Motorcycles
Kyocera hydro c5170 wont power on
Dear Brohter:
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Dec 08, 2012 | Kyocera Cell Phones
Wiimote unresponsive to anything
Have you tried restarting the Wii and then synching the wii remote to the wii ?
Just below the disk loader is a hinge you can open to insert a sd card, There is a red button - Push it
Take the battery cover of the wii remote, their is a red button - push it
Push both buttons close together time wise
Aug 12, 2009 | Nintendo Wiimote & Nunchuk Controller...
Power
ok..remove battery..try it on ac alone..
Feb 19, 2008 | Computers & Internet
Freezing
I felt like an idiot when I couldn't fix this problem. Take out the battery and put it back in.
Apr 15, 2007 | SanDisk Sansa m230 MP3 Player
Cameras Logo
1,139 people viewed this question
Top FUJIFILM Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Falling star
Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
