So i have the AIWA CX-ZR525 and when i go to play a cd it will pick up the disc once in the tray but it will not spin/ play music.
Presuming that other sources work okay and the the cables are connected correctly.....Try a CD Lens cleaner.
If that doesn't work then it's time to open up the unit and manually clean the laser lens. If that still doesn't work then the laser might be dead. Replacement parts may be available. Whether or not you can do this as a DIY repair though is questionable. It depends on your skill.
SOURCE: Kenwood XD-A55 CD player shows 'no disc'
The first thing you got to do is clean the laser lens maybe is dirt,witha qtip wet with alcohol clean the lens then with the dry part clean the residues of alcohol good luck
