Question about Astar LTV-2701 27 in. HD-Ready LCD Television
Astar tv wint turn on
Have to turn switch on and of numerous times to get the thing to come on. astar wont reply back give info
  • Anonymous Nov 11, 2007
    Had Astar LCD HDTV for less than a year and the green light comes on but on picture or sound.
  • ainternetguy Dec 13, 2007
    My Astar flat panel 27" won't turn on with the on/off switch on the tv. I have to use the remote. Is there a service update from Astar? If not, and there are this many problems ... we should be able to get a regulatory body involved with a recall or class action suit
Anonymous
This company is no longer in business. They were sued by Phillips for various copyright infringements and were forced out of business when they didn't comply with the lawsuit. We lost out on our rebate check and the fees it cost us, so I know all about it....
Posted on Jan 01, 2008
Anonymous
So what do we do with a astar tv that doesn't work i have 2 and they need to be fixed what now any help would be great
Posted on Jan 04, 2008
I seem to have a short in my main power switch on my astar tv
it won't be the mainpower swith problem,your tv has a fault,u wiggle the main power swith,the tv lose the memory of the fault,it's like a reset the tv,and then the tv back on again.
Mar 29, 2009 | Astar LTV-2701 27 in. HD-Ready LCD...
32"ASTAR problem
Please call 323-767-6030 and I will trying to help you as much as I can for the astar ltv-3201 tv.
Jan 30, 2009 | Astar LTV-3201 32 in. LCD Television
Smoke coming from the back
power board shot. remove power board and purchase the exact board with the numerical stamp on the board usually 12-16 characters. make sure it matches, replace board and reasemble tv and enjoy.
ASTAR LCD TV 32'' won't turn on any more.
I have cable connected to my astar tv. I have the same problem whenever I turn my tv off of not getting the tv to come back on. What works for me is 1. Reset power- turning off both the tv
Nov 17, 2008 | Astar LTV-3201 32 in. LCD Television
Astar tv sometimes won't power on
There is a history of failing power suplies on these LCDs. If the LCD fails to power up, it means that the power supply needs to be replace or repair.
If you require further info on repairing the power supply, write to [email protected]
Nov 12, 2008 | Astar LTV-2701 27 in. HD-Ready LCD...
AStar Ltv-2701
It appears to be a power supply failure. In about 95% of cases is a defective power supply that causes the TV to behave as per your description.
If you need more info you can email [email protected]
Jul 01, 2008 | Astar LTV-2701 27 in. HD-Ready LCD...
Astar LTV-3001
I've sent you the info to your hotmail.
May 07, 2008 | Astar LTV-3201 32 in. LCD Television
Astar Power Supply
Fixing the internal power no problem depending the power board it's burn or not. second thing is your LTV-32HBG TV with one HDMI connection or two HDMI connection? I know more about these Astar TV because I have work for the Astar co as an electronic technician before and I only give out such information how to repair these tv. so, call 323-767-6030 and I will help you go through with you problem by the phone.
Mar 18, 2008 | Astar LTV-20PW 20 in. EDTV-Ready LCD...
Wont power on
I also have an Astar TV which turns on and flashes the Astar logo before the screen shuts down (Green power light stays on). From what i understand this is generally caused by low grade parts and to much heat. I dont know if you have gotten close to the TV while it is running but it gets extremely hot. The main issus with this is it causes the Capacitors to blow. there are about 20 of them and they generally sell for about $1.25 - $6 each online. If you have any experience soldering i have read about other people performing the fix themselves. I dont so i am currently looking into the cost to have them replaced by a professional. I will try and post what i find out.
Nov 07, 2007 | Astar LTV-2701 27 in. HD-Ready LCD...
Astar LTV-2701 27 in. HD-Ready LCD Television Logo
Top Astar Televison & Video Experts
Marvin
Marvin
Are you an Astar Televison and Video Expert? Answer questions, earn points and help others
