What would be the possible problem ?
Sorry to say but this is a result of a failed firmware or map upgrade. Sometimes a break in the data communication between your GPS and PC can cause a failed upgrade. When you turn on the unit and it just displays the Garmin logo, sometimes in an endless loop, this is a boot problem. The unit can not find the proper files or they are corrupted. More information can be found here: SHARCNET USA Out of Warranty GPS Digital Camera Repair Center
SOURCE: Garmin 1450 stopped working. Garmin shows on
I would register you GPS at the Garmin website https://my.garmin.com/mygarmin/customers/myGarminHome.faces and see if there is a software update available. If so I would do the update. If there is any damage to the software it should get fixed. To register and update your GPS you will need a USB cable to connect it to your computer. You will also need to create an account through the Garmin website. Once you are finished registering your device(the website well walk you through it) you should be able to find the software update under "MyDashboard" link.
SOURCE: Just purchase Garmin nuvi 1450
You can download and print the instruction manual in PDF format from this link.
On the page which opens, click on the "Manuals" link. Then download the manuals (Owner's Manual and Quick Start Manual) from the next page.
Adobe PDF Reader is required to view the manuals. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manuals.
Thanks for using FixYa.
Your feedback is important to us!
Kindly rate and accept the solution if it helps you.
SOURCE: Tried shutting it off. It won't shut off or
Hi, A soft reset will preserve your Home, Favorites, POis, etc.or just remove the battery. Leave the battery in the unit. Hold down on the lower right of the screen while holding down on the power button. After 20-30 seconds, you should see the Garmin splash screen. Have your PC/laptop ready with USB cable. Get the latest Map update downloaded and installed or just start using the unit again. i hope this will be very helpfull to you. please don't don't forget to vote me Good Luck
SOURCE: how do i register my
The LMT versions are pre activated so all you need to do is go to www.garmin.com navigate to the my dashboard tab. there you will find a field to login or create a new account. From there it is a step by step process to getting it registered. you will need you USB cable or the unit serial number from the box bottom of the unit.
Hope this helps
SOURCE: Yes, whats the difference between fast route &
This is real simple, fast route on all GPS,S including yours simply means fatest route by time to get there based on best roads and speed limits. Shortest route might be shorter in miles per say, but not always the fastest, because it will take you threw neighborhoods or back roads , school zones etc.... So, most the time you will and should use fastest route as it is best time, fuel economy and safest. Please if this has helped you, then respond with 4 thumbs up and a small positive testamony. Thanks, mr guru bean from fixya. Com
