Can I remove the rubber seal on the top of the badger 5 garbage disposal to clean it then put the rubber back on or will this destroy the rubber seal?
Full user manual for this here. Cleaning it etc.
Don't think you would destroy the seal if you are careful. Sure you could get a spare if you did from their answerline at top of manual.
http://www.scribd.com/doc/9725184/Badger-5-garbage-disposal-user-manual
SOURCE: water draining backinto dishwasher from garbage disposal
You have a clog where the drain pipe leaves the garbage disposal that isn't draining fast enough or not at all. Or it could be a clog in the dishwasher drain hose where it connects onto the disposal.
SOURCE: sink garbage disposal not working! when I switch
Do you hear a humming sound when you turn it on? If so, you have a clogged disposal. Check on the bottom for the allen wrench location recessed in the middle of the disposal. Insert the proper size allen wrench and you'll be able to rotate the motor back and forth (sometimes difficult at first) and eventually loosen the clog and free up the motor. If you're able to move the shaft/motor easily in the beginning and it still doesn't work you may have a defective disposal. If you want to check more thoroughly you'll need to check to see if you have power at the disposal when you turn on the switch. Use a electrical tester that you can buy at any home improvement store to see if you have power at the disposal. If so, and the motor turns easily when you use your allen wrench, you have a defective disposal and it needs replacement.
SOURCE: shot gun b b in garbage disposal, can't locate to remove. help.
Use vacuum cleaner down into disposal.
Copy following link for general troubleshoot tips:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
