Question about Wolf Range 18 in. SPR-100 Gas Cooktop
Wolf range cooktop
The ignition spark for one of the burners does not stop clicking. When I turn on that burner it stops but otherwise continually keeps going. I have tried all other alternatives (changing the pieces that distribute the gas from another burner, etc). It is driving the family crazy, Any suggestions would be greatly appreciated. hs
Posted by henry4575 on
  • 7 more comments
  • Anonymous Nov 22, 2007
    When trying to light the center grill burners, the ignition will not shut off,even when it is lit. This is on a 36" stovetop.
  • Anonymous Dec 03, 2007
    The sam, starter does not stop
  • Anonymous Dec 30, 2007
    I have the same problem with only the grill feature. have you had any success in fixing the problem?
  • Anonymous Jan 06, 2008
    We have the same problem with the ignition clicking; however, it came on after several months of problem-free use. We have not figured out how to stop the clicking that started on one burner and has now started on one other burner.
  • fredbarb Aug 18, 2008
    One large burner on my 5 burner wolf gas cooktop keeps clicking after I turn it on. The burner lights fine just the clicking keeps going. Not sure how to fix the problem. What can I do it get to stop once the flame comes on?
  • Anonymous Aug 18, 2008
    I have the same problem with the igniter - it won't stop clicking after I light the burner. All other 5 burners/igniters are fine.
  • Anonymous Aug 26, 2008
    same problem in four burner stove. will definitely check the polarity. general applicable service person did not know why it was doing this.
    thanks for the suggestion..
  • Anonymous Dec 09, 2008
    same problem with largest cooktop gas Wolf unit
  • idogr8smiles Feb 16, 2009
    All five of mine click constatly.
Fox51
    New Friend:
My new Wolf R304 burners click on high when there is a pan on the burner, but not if there is no pan. Local repair tech and Wolf techs have not been able to resolve the issue or duplicate it in the stove they took back. Local gas company technician told us the clicking is an issue in automatic relighting burners and that Wolf is the best of the lot. He also explained that there is no longer an adjustment of air feed for the burners to tweak the air flow of the burner while on high, and the heat sensor isn't staying hot enough for the ignition to know that the burners are lit. After observing the pattern of the flame while on high I have been able to resolve the clicking by making sure that the slot leading to the outer ring is NOT located near the white heat sensor.
BTW, the polarity of our outlet is correct, as checked by my Electrical Engineer Electrician.
Posted on Sep 07, 2010
  • Fox51 Apr 08, 2014
    Nearly four years later I finally figured out the clicking problem on this stove. If I pick up the pan when its clicking, the bottom of the pan and the burner grate have moisture on them, which indicates condensation from the gas. I now turn on the burner without a pan on it to preheat the grate, so when I put the pan on the burner, there's no condensation and no clicking. It was gas quality afterall.
  • Kagey Sep 11, 2018
    Amazing!! Professionals were of no help with constant clicking when smaller burners were set to lowest flame. Cleaned, brushed, cursed. For 10 years! Browsed here and thank my lucky stars I came across your solution. Can’t thank you enough!!!
Anonymous
I just installed a Wolf gas cooktop and had the same problem in that all 4 burners would light just fine but the electronic igniters would not stop clicking on all four. What I found was that the electrical outlet that my gas cooktop was plugged into had the polarity reversed. I tested the outlet with a polarity testing module (you can get one at Home Depot and it checks polarity, grounding, GFI and is handy to have around, small and inexpensive). I plugged it in and the lights told me that the polarity was reversed. I reversed the wires in the outlet (exchanged the white and black wires) put the cover back on, plugged in the cook top and now it works like a champ! no more constant clicking. By the way, we had a cooktop before this one with electronic ignition and never had a problem, apparently it didn't care about the polarity.
Posted on Dec 29, 2007
Anonymous
    New Friend:
Align the little slot up with the ignitor.. it should point directly
Posted on Oct 22, 2010
My Viking vgsu cooktop has the igniter go on continuously when I try to turn on 4 of the 6 burners
My Viking stove igniter won't stop clicking. Both igniters on one side are clicking over and over
May 21, 2010 | Cooktops
The ignitor will not stop sparking.
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
May 23, 2010 | Jenn-Air 30 in. JGD8430A Gas Cooktop
Same one - ignition click will not stop. Is there a solution?
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
wwttw
Sep 25, 2009 | GE 30 in. Profile JGP933 Gas Cooktop
Old Thermador cooktop continues to spark even after turned off
sounds like you have a bad switch. maybe on the large burner.. some of those switches can be replaced without the whole harness.
Dec 22, 2008 | Thermador PSC364GDZS Gas Cooktop
Stove-top burners
heatman101
bvn
Jul 10, 2008 | Belling 27 in. CTC465 Electric Cooktop
Wolf Range 18 in. SPR-100 Gas Cooktop Logo
9,406 people viewed this question
Top Wolf Range Cooktops Experts
Alan Chouinard
Paul Carew
ray gallant
Are you a Wolf Range Cooktop Expert? Answer questions, earn points and help others
