230-240v ~ 50Hz 10a Pmax 2050w 900 r.p.m. 1700
If the drum is not turning, the motor control board is faulty. This may just be a bad solder joint, but you'll need someone with electronics knowledge to check and repair it.
SOURCE: dial clicks round
Open the rear panel and look for a broken or worn belt. If this is the problem you can replace it easily. Good luck !
SOURCE: Washing machine is not completing it's wash cycle
either you have a blocked hose to the pump or the pump itself is either jammed or the impellor has come off the shaft. either way i think you will need to replace the pump. i presume you managed to get the water out? if so i would say the pump is favourite.
